Switching
Get 20% off switches when you combine Cisco solutions
Labels
Am trying to create a new local account on a Nexus 3048 so I can SSH to it if my Radius server doesn't work.  Normally, I log in with my AD account which the switch uses Radius for authentication with that.  However, when I run the command to create ...
mramj499 by Level 1
  • 60 Views
  • 1 replies
I am trying to configure a trunk port on a Cisco 3750 that has fiber running to a ruckus 7150 switch.My current config connects the switches but it is only passing vlan1 traffic and I want multiple vlans. Therefore, I configured the port as a trunk o...
oowJ by Level 1
  • 124 Views
  • 3 replies
Dear community I am getting into NetFlow a little bit deeper but cannot get my head around sampling. All i understand so far: We can configure deterministic sampling, that uses a hardware sampler per interface, limiting the maximum number of monitori...
Hi All , I am in the testing phase of migrating to a 9300. So far I have done the below.3850 running 16.3.6   and 9300 updated 17.09.04aI have copied the start-up config to the 9300 - all looks ok apart from the usual ip routes , some interfaces not ...
machine23 by Level 1
  • 101 Views
  • 2 replies
Resolved! Networking
Hi everyone, I have a Cisco catalyst C1200-24P-4X switch, and I want to enable stacked VLAN configuration on it. Does it can support the feature?
moges1 by Level 1
  • 115 Views
  • 1 replies
Hello, CML (Cisco Modelling Lab) 2.5 announced a virtual Catalyst 9000 running IOS-XE 17.10 - I tested this out on my personal CML 2.6.1 and I am struggling to get 802.1X working. I know Cat 9K virtual is still a beta release and the CML folks can't ...
I am configuring a DHCP Server for a small VLAN.I have configured vlan 10 20 30 and trunk access for switch interfaces, activated fa0/0.1, fa0/0.2, fa0/0.3 as example belowint fa0/0.1 encapsulation dot1Q 10 ip address 192.168.10.1 255.255.255.0 ip he...
