3750 disaster recovery
mtechnology
My 3750 switch is not booting and is stuck at the prompt switch:
i tried to initialize the flash and load the IOS via the boot command but it gives an error.
Is there any xmodem procedure which i can do to load another software
Amit Singh
Yes, you can use Xmodem to recover the switch. Please use the link below for recovering 3750 from softwaqre failures:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a0080476281.html#wp1099467
HTH,Please rate if it does.
-amit singh
ankbhasi
Hi Friend,
Have a look at this link
http://www.cisco.com/warp/public/473/192.html#topic2
Ankur
*pls rate all helpfull post
Amit Singh
-amit singh
thanks for the link..
Is there anyway to increase the baud rate cos it is taking a long time to load the file with the normal rate
podhillo
Please try the following steps to disaster recovery.
Do check the connections before proceeding:
flash_init
load_helper
dir flash:
set baud 115200 ---> for faster trasfer of image, do open a new hyper terminal with baud rate set to 115200.
copy xmodem:flash:
More details provided in the following link:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Hope it helps!
podhillo
