05-08-2009 12:02 PM - edited 03-06-2019 05:37 AM
HI,
I have a WS-C3750G-12S-S and want to upgrade it by ordering CD-3750G-EMI=.
now when i enter "show ver" command it shows model information as "WS-C3750G-12S-S" my question is that after upgarding it to enhanced version will that command show model information as WS-C3750G-12S-E ? i am sure that upgarding the IOS image will not change that information which burned in Flash/EEPROM of the switch.
Saeed Zamani.
05-10-2009 05:08 PM
Hi Saeed,
When you upgrade the license from Standard to Enhanced, your switch should respond with an "E" suffix.
05-10-2009 10:56 PM
i copy output of show version command here , you see it still shows model number as 12S-S , even in ROMMON there is a set command that you can change model number, i did that and at booting time it shows 12S-E but after boot, show version shows 12S-S again.
cisco WS-C3750G-12S (PowerPC405) processor (revision N0) with 118784K/12280K bytes of memory.
Processor board ID FCZ12284J5G
Last reset from power-on
1 Virtual Ethernet interface
12 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:23:EA:63:4A:80
Motherboard assembly number : 73-9678-08
Power supply part number : 341-0048-03
Motherboard serial number : FDO12450L54
Power supply serial number : DTN124130V7
Model revision number : N0
Motherboard revision number : A0
Model number : WS-C3750G-12S-S
System serial number : FCZ12284J5G
Top Assembly Part Number : 800-25856-05
Top Assembly Revision Number : C0
Version ID : V07
CLEI Code Number : CNM82V0GRA
Hardware Board Revision Number : 0x06
Switch Ports Model SW Version SW Image
* 1 12 WS-C3750G-12S 12.2(25)SEB2 C3750-ADVIPSERVICESK
Configuration register is 0xF
Saeed.
05-10-2009 09:54 PM
I will be performing the identical upgrade tomorrow - I will do a "before" and an "after" show ver for your information.
05-12-2009 04:19 PM
Yep - no change
System image file is "flash:c3750-ipbase-mz.122-35.SE5/c3750-ipbase-mz.122-35.SE5.bin"
cisco WS-C3750G-12S
AFTER:
System image file is "flash:c3750-ipservices-mz.122-50.SE1/c3750-ipservices-mz.122-50.SE1.bin"
cisco WS-C3750G-12S
05-13-2009 02:25 AM
anyway that change model number by command?
Saeed Zamani.
