3750 stacking problems with new switch
Claus Andersen
At a customer i've tried to add a new 3750 switch til a running stack.
I used the following proccess:
1. connect stack cables to the new switch
2. bootup new switch.
Normaly the new switch will become a member of the stack, but here, the switch says its the stack master. I can see that the stack port from the old swtiches connecting the new is up.
The only way i could make it work was to provisioning the new switch as switch nr x, save, power off and then connecte it and boot it up.
The IOS i the same on all switches.
/claus
Somasundaram Jayaraman
Could you please check the priority in both the switches?
from the show sw detail output you can see the priority configured in both the switches.
++ Higher the priority of the switch more chances of becoming the master.
To change the priority,
switch priority <1-15>
++ The new priority will take into effect only if the switch is reloaded.
By default the priority would be 1.
-http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml
Hope this answers your question.
Cheers
Somu
Rate helpful posts
Hi Claus,
Follow the below link about the procedure how to add a new switch to an existing stack.
http://www.thenetworkadministrator.net/index.php/2011/01/adding-a-cisco-3750-switch-to-an-existing-stack/
Please rate the helpfull posts.
Naidu.
