12-22-2010 12:13 PM - edited 03-06-2019 02:39 PM
I'm running accross two problems:
I've 3750 switch configured with following:
switch 1 provision ws-c3750-48p
so it shows fastEthernet ports, no Gig ports.
when I try to configure it with:
switch 1 provision ws-c3750-48ps - it doesn't take even though this switch is gig switch. how to resolve it?
2) as in config shown below. intervlan routing is enabled but still cant reach any host from vlan 2 to host in vlan 3. I can reach the default gateway of vlan3 from vlan 2 though.
interface Vlan2
 ip address 192.168.2.3 255.255.255.0
 standby 2 ip 192.168.2.1
 standby 2 priority 90
 standby 2 preempt
interface Vlan3
 ip address 172.7.2.3 255.255.252.0
 standby 3 ip 172.9.2.1
 standby 3 priority 90
 standby 3 preempt
i.e. PC1 IP address: 192.168.2.100
PC2 IP address: 172.7.2.3
PC1 can ping 172.9.2.1 but it cant ping 172.9.2.3. and same thing happens with PC2.
Confg. of switch is as below:
Current configuration : 7987 bytes
version 12.2
no service pad
hostname SW2
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$5SHB$2.H60/Zuf5V3Gw0YdhfGW.
no aaa new-model
system mtu routing 1500
vtp domain domain
vtp mode transparent
authentication mac-move permit
ip subnet-zero
ip routing
no ip domain-lookup
crypto pki trustpoint TP-self-signed-1137764352
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1137764352
 revocation-check none
 rsakeypair TP-self-signed-1137764352
crypto pki certificate chain TP-self-signed-1137764352
 certificate self-signed 01
  30820240 308201A9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31313337 37363433 3532301E 170D3933 30333031 30303031
  30395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 31333737
  36343335 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100E0C7 14DA215C 2325ED1C C2CD2D53 5A9835AD 13676CE7 2738DC4B 49CDF66A
  03C34EB3 802C0B51 610F79E7 24B671CD 64E64636 069BC588 92DE22C8 2A1304A1
  A13E8F69 FB4654B2 CA343D7D B5F9AEE4 57CAAE89 A4C0C97B FC26F8C0 B3FD77DF
  D486C3B4 0F2080F3 3F489D8C 0165F7C2 6E725CB6 BDF196AB 5AFAEBE8 0A070B90
  F77D0203 010001A3 68306630 0F060355 1D130101 FF040530 030101FF 30130603
  551D1104 0C300A82 084D4553 2D535732 2E301F06 03551D23 04183016 8014C3B9
  7848F306 09DEE7B5 86ED3010 0579BBD7 A8D7301D 0603551D 0E041604 14C3B978
  48F30609 DEE7B586 ED301005 79BBD7A8 D7300D06 092A8648 86F70D01 01040500
  03818100 57A3B357 D06DFAD5 163A3339 1705732E 101648C3 BC7659CA 19A45DDC
  3F0595F4 15E076BE 9A33AA49 D2A0269B 2C59025E 5B2295DC 8287CA68 3B371545
  7975FC5C DA456872 C02136A8 A2347742 335E2B71 ABE08F2E 27A25FA3 77663E72
  4770DBE2 60590AE1 3215782A F82B6EA5 EA46FDAB 62364A0C BAEB8D69 DE1AB7AA 4F466569
  quit
errdisable recovery cause bpduguard
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
vlan 2
 name Vlan2
vlan 3
 name Vlan3
vlan 4
 name >Vlan4
interface Port-channel1
 description > To-SWITCH 1
 switchport trunk allowed vlan 2-4
 switchport mode trunk
interface FastEthernet1/0/1
 description Vlan2
 switchport access vlan 2
 switchport mode access
interface FastEthernet1/0/2
 description Vlan2
interface FastEthernet1/0/3
 description Vlan2
interface FastEthernet1/0/4
 description Vlan2
interface FastEthernet1/0/5
 description Vlan2
interface FastEthernet1/0/6
 description Vlan2
interface FastEthernet1/0/7
 description Vlan2
interface FastEthernet1/0/8
 description Vlan2
interface FastEthernet1/0/9
 description Vlan2
interface FastEthernet1/0/10
 description Vlan2
interface FastEthernet1/0/11
 description Vlan2
interface FastEthernet1/0/12
 description Vlan2
interface FastEthernet1/0/13
 description Vlan3
 switchport access vlan 3
interface FastEthernet1/0/14
 description Vlan3
interface FastEthernet1/0/15
 description Vlan3
interface FastEthernet1/0/16
 description Vlan3
interface FastEthernet1/0/17
 description Vlan3
interface FastEthernet1/0/18
 description Vlan3
interface FastEthernet1/0/19
 description Vlan3
interface FastEthernet1/0/20
 description Vlan3
interface FastEthernet1/0/21
 description Vlan3
interface FastEthernet1/0/22
 description Vlan3
interface FastEthernet1/0/23
 description Vlan3
interface FastEthernet1/0/24
 description Vlan3
interface FastEthernet1/0/25
 description Vlan4
 switchport access vlan 4
interface FastEthernet1/0/26
 description Vlan4
interface FastEthernet1/0/27
 description Vlan4
interface FastEthernet1/0/28
 description Vlan4
interface FastEthernet1/0/29
 description Vlan4
interface FastEthernet1/0/30
 description Vlan4
interface FastEthernet1/0/31
 description Vlan4
interface FastEthernet1/0/32
 description Vlan4
interface FastEthernet1/0/33
 description Vlan4
interface FastEthernet1/0/34
 description Vlan4
interface FastEthernet1/0/35
 description Vlan4
interface FastEthernet1/0/36
 description Vlan4
interface FastEthernet1/0/37
interface FastEthernet1/0/38
interface FastEthernet1/0/39
interface FastEthernet1/0/40
interface FastEthernet1/0/41
interface FastEthernet1/0/42
interface FastEthernet1/0/43
interface FastEthernet1/0/44
interface FastEthernet1/0/45
interface FastEthernet1/0/46
interface FastEthernet1/0/47
 description > To-SW1 G1/0/47
 channel-group 1 mode active
interface FastEthernet1/0/48
 description > To-SW1 G1/0/48
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface Vlan1
 no ip address
 shutdown
interface Vlan2
 standby 2 preempt
interface Vlan3
 standby 3 preempt
ip classless
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
12-22-2010 12:27 PM
Is your switch ws-c3750-48ps-E or ws-c3750-48ps-S?
12-22-2010 12:56 PM
If you are trying to ping a pc or server make sure all windows firewalls are shutoff on the pc's or servers before pinging .
12-22-2010 01:23 PM
this switch is WS-C3750-48PS-S - so it doesnt have gig ports. my bad. thx...
switch1:
interface Vlan2
ip address 192.168.2.2 255.255.255.0
standby 2 preempt
interface Vlan3
ip address 172.7.2.2 255.255.252.0
standby 3 preempt
switch 2:
interface Vlan2
 standby 2 preempt
interface Vlan3
 standby 3 preempt
PC1: 192.168.2.107 <--on switch1
PC2: 172.7.2.107 <- on switch2
PC1 on switch1 is able to ping 192.168.2.2, 192.168.2.1,192.168.2.3 and 172.7.2.2, 172.7.2.1& 172.7.2.3 but i can't ping 172.7.2.107 doesn't look like firewall is on. pls advise.
12-23-2010 04:12 AM
Hi, it seems to me that the standby ip is out of range
interface Vlan3
>> standby 3 ip 172.7.2.1
Good luck.
