3750-X StackPower-Problem
Hi all,
I have a problem with a stack of four 3750-X (IPBase, 12.2(55)SE3)
Scenario:
- Sw1 and Sw2 form a power-ring
- Sw3 and Sw4 form a power-ring
- only Sw2 has an additionnal PS
The only power-config I have is the following:
stack-power stack power1
mode redundant
stack-power switch 2
stack power1
stack-power switch 1
stack power1
Every minute I get the following log-message:
Jul  6 13:47:47 CEST: %PLATFORM_STACKPOWER-4-PRIO_CONFLICT: Switch 1's power stack has conflicting power priorities
The Message-guide didn't help me any further ...
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_55_se/system/message/msg_desc.html#wp1124977
Any idea what can cause these messages?
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
In power stack 1 the "High port priority value" is the same for both switch 1 and 2. Could change one of those to have unique values and check for errors after that?
Power stack name: power1
    Stack mode: Redundant
    Stack topology: Ring
    Switch 2:
        High port priority value: 12
    Switch 1:
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
5 Replies 5
Ivan Shirshin
This message indicates there are two sets of devices (either a switch or a set of PDs) within the same power stack that have the SAME priority level (1 - 27).  If you saw this once, it's likely it just occurred while you were configuring their priorities.
Please check the priorities first and share the outputs of "show stack-power" and "show env all". If there are matching, then you need to change that. e.g.:
     Switch(config)#Stack-power switch 4
     Power-priority high 11
     Power-priority low 23
     power-prority switch 5
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_55_se/configuration/guide/swstkpwr.html#wp1016452
If it is continually happening even the output of "show stack-power" shows there are different, then there is chance you hit CSCtg20513. You can either upgrade the IOS or apply a workaround:
     - toggle the stack ports (shut/no shut) on the unit that is incorrectly reporting this error.
          config t
               stack-power switch
               standalone
               no standalone
Kind Regards,
Ivan
Kind Regards,
Ivan
the toggling of the ports didn't help. The priorities are all different:
sw-ham1-core-01#show stack-p
    Switch 2:
        Power budget: 223
        Low port priority value: 20
        Switch priority value: 2
        Port 1 status: Connected
        Port 2 status: Connected
        Neighbor on port 1: c464.13a0.9780
        Neighbor on port 2: c464.13a0.9780
    Switch 1:
        Power budget: 223
        Low port priority value: 21
        Switch priority value: 5
        Neighbor on port 1: c464.13a0.b600
        Neighbor on port 2: c464.13a0.b600
Power stack name: Powerstack-3
    Stack mode: Power sharing
    Switch 4:
        Power budget: 190
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 4
        Neighbor on port 1: 503d.e5c8.0d80
        Neighbor on port 2: 503d.e5c8.0d80
    Switch 3:
        Power budget: 190
        Switch priority value: 3
        Neighbor on port 1: 503d.e5c8.1f00
        Neighbor on port 2: 503d.e5c8.1f00
sw-ham1-core-01#sh env a
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is NOT PRESENT
TEMPERATURE is OK
Temperature Value: 29 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold    : 60 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-350WAC     LIT154009G8  OK              Good     Good     350/0
1B  Not Present
2A  C3KX-PWR-350WAC     LIT154100KM  OK              Good     Good     350/0
2B  C3KX-PWR-715WAC     LIT154314Z1  OK              Good     Good     715/0
3A  C3KX-PWR-350WAC     LIT145108RW  OK              Good     Good     350/0
3B  Not Present
4A  C3KX-PWR-350WAC     LIT145108S6  OK              Good     Good     350/0
4B  Not Present
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
2   Not Present     <>
3   Not Present     <>
4   Not Present     <>
    Switch 2:
    Switch 1:
Kind Regards,
Ivan
Kind Regards,
Ivan
Thanks Ivan, that did it! I wasn't aware that also these High-values had to be different.
welcome, Karsten!
Kind Regards,
Ivan
