3750E flash memory
godspeeds
I've got a 3750E switch which should have 64M flash memory, but it only shows me about 55M by show version command.
Does anyone know where the 9M memory is? What is used for?
Thanks.
3750E#dir flash:
Directory of flash:/
    2  -rwx        3096   Mar 1 1993 00:01:25 +00:00  multiple-fs
    3  -rwx    17866988   Mar 1 1993 12:38:28 +00:00  c3750e-ipbasek9-mz.122-58.SE2.bin
    5  -rwx        1915   Mar 1 1993 00:01:24 +00:00  private-config.text
    6  -rwx        1336   Mar 1 1993 00:01:01 +00:00  vlan.dat
    7  -rwx        2736   Mar 1 1993 00:01:24 +00:00  config.text
57671680 bytes total (39646720 bytes free)
3750E#
jmherlih
I too am looking for this solution.  I want to upgrade the code on my 3750e and want to make sure all is well before I try the upgrade.
You can upgrade your 3750E to IOS version 12.2(58)SE or 15.0(1)SE.
Leo Laohoo
Some should go to the NVRAM.  Enter the command "dir nvram:".
Thank you.  Yesterday I was able to manually extract the tar for 12.2(58)SE2.  Still would like to resolve the issue with the flash memory.  We use LMS to do code upgrades, and when LMS cannot find the desired flash, the job fails.  For this switch it was looking for 64meg.  I think this can be manually adjusted within LMS, but wonder where the memory went.
