3750G-48TS Power utilization Command
What commands are used to check power utilization on Switch 3750G-48TS.
Please guide me asap.
Prashant Gondaliya
enkli
show power inline
show env
what do you mean for power on port or whole switch
Hi Enkli,
Thanks for immediate reply. I have apply these 2 commands.
I want to know utilization of power ( like 90 Watts etc..), even we can say power consumption by switch.
Prashant Gondaliya
Try this command:
"sh power inline consum def"
Leo Laohoo
You can't. Your switch is not a PoE version. Do you want to look at the status of your switch's environmentals? Then the command you may use is "show environment all".
Does this help?
