03-02-2010 07:17 AM - edited 03-06-2019 09:57 AM
I have a 2 3750G 24T's that are connected via Stackwise cables that has recently started kicking out some errors and I cant seem to make heads or tails out of them. Here are the errors:
Mar 1 11:05:30: %LINK-3-BADMACREG: Interface StackPort1, non-existent MACADDR registry for link 0
-Process= "<interrupt level>", ipl= 4
-Traceback= 209FC4 187B7C 58A494 5886E8 2D7800 2DF894 2E2360 2E268C 2B0858
I have checked the stackports to verify connectivity and they all seem to be up and operating fine.
I can't seem to get any information from the command output tool other than contact TAC. Unfortunately, there is no maintenance on this switch and I can't create a ticket.
The version of IOS that is currently on this switch is an older version of 12.1(19)EA1c. I am assuming I can upgrade to 12.2(35)SE (correct me if i'm
wrong). However, I'm not sure this is an IOS problem/Hardware issue or just a config issue.
Any help or information would be greatly appreciated.
Thanks in advance,
Solved! Go to Solution.
03-02-2010 08:36 AM
Looks like TAC is the only option here. I wouldtry a software upgrade since you don't have support.
Explanation An attempt to map a network level address to a MAC level address has failed.
Recommended Action Copy the error message exactly as it appears on the console or in the system log, contact your Cisco technical support representative, and provide the representative with the gathered information.
http://www.cisco.com/en/US/docs/ios/12_3/sem1/system/messages/emglcfe.html
03-02-2010 08:48 AM
Looks like you are hitting bug ID CSCee14673.
It should be fixed in the new IOS version like the one you said. However, I will go to 12.2(44)SE6 or so.
HTH,
jerry
03-02-2010 08:36 AM
03-02-2010 08:48 AM
HTH,
jerry
03-02-2010 09:26 AM
Thank you for your help. It does appear as though thats what my problem is. I will attempt to upgrade my software and see
how that goes. Thanks again.
