3750X-48T Blocking
robert.horrigan
Level 2
Level 2
Hi, the data sheet for the device in the subject does not show the blocking ratio for port forwarding, ie 20:1.
It does provide the switching fabric 160Gb and forwarding rate 101.2 mpps.
My question is, what is the blocking ratio for this switch and if it's not on the datasheet, how can it be determined?
Jon Marshall
Robert
Not exactly sure what you mean. The 3750X switches are like the 3750-E switches ie. they are non-blocking.
Jon
