Highlighted
Beginner
3750x inbound port policing
Guys,
dont seem to be able to get policing working inbound on a port 3750X v 15.0(2)
Config is below:
ip access-list extended SMB
permit tcp host 192.168.1.14 host 172.16.1.30
permit tcp host 192.168.1.14 host 172.16.1.31
class-map match-any SMB
match access-group name SMB
policy-map POLICE-SMB
class SMB
police 1000000 8000 exceed-action drop
interface GigabitEthernet1/0/16
service-policy input POLICE-SMB
192.168.1.14 - connected to the port
172.16.1.30 and 31 - destination servers across WAN
Anything wrong with the above
sh policy map interface - shows nothing matching at all and transfere rate of 10Mbps not being policed.
Cheers
1 ACCEPTED SOLUTION
Highlighted
Thanks for the information supplied.
Will you please refrain from using the "show policy-map interface" command as according to the Cisco docs excerpt (for Cat3750X & 15.0(2)IOS):
Note Do not use the show policy-map interface privileged EXEC command to display classification information for incoming traffic. The control-plane and interface keywords are not supported, and the statistics shown in the display should be ignored.(Configuration Guide)
Note Though visible in the command-line help string, the control-plane and interface keywords are not supported, and the statistics shown in the display should be ignored.(Command Reference)
Best regards,
Antonin
6 REPLIES 6
Highlighted
Rising star
Have you enabled QoS globally via the "mls qos" command?
Best regards,
Antonin
Highlighted
SW01#sh mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled
Yes - its enabled globally.
Cheers
Highlighted
GigabitEthernet2/0/17
  Service-policy input: POLICE-SMB
    Class-map: SMB (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name SMB
        0 packets, 0 bytes
        5 minute rate 0 bps
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
Dont see anything change in the "show policy-map int" command output.
Highlighted
Best regards,
Antonin
Highlighted
Rising star
Further to my previous post I would like to let you know that I have set up the scenario in my lab using your configuration and it works perfectly OK. While indeed "show policy-map interface" command output shows just zero counts as in your post the "sh mls qos interface Gi1/0/16 statistics" output displays correct numbers for the policer for both InProfile and OutProfile counts (corresponding the policing parameters configured).
Best regards,
Antonin
Highlighted
Cheers for the info Antonin.
below is the interface - so yes it looks like its working:
GigabitEthernet1/0/9 (All statistics are in packets)
  dscp: incoming
  0 -  4 :   311655693            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :   478116148            0           42            0            6
  5 -  9 :           0            0            0     69138759            0
10 - 14 :        5534            0            0            0            0
15 - 19 :           0      6645267            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0        20983            0            1            0
30 - 34 :         434            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0        68054            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :   582153387            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :   494011469     69112310            0            0            0
  5 -  7 :           0            0        88092
  output queues enqueued:
queue:    threshold1   threshold2   threshold3
queue 0:           4           0           0
queue 1:   196250618      163235      304665
queue 2:           0           0           0
queue 3:           0           0   366584251
  output queues dropped:
queue 0:           0           0           0
queue 1:       23559           0           0
queue 2:           0           0           0
queue 3:           0           0        1858
Policer: Inprofile:      4714038 OutofProfile:       514707
Thanks for yout time and links etc
Content for Community-Ad
