3750X Stack with 3750E
Juan Ibañez
Hi i have 2 Switch 3750E in Stack, but i have an 3750X, and i would like insert this last in the stack, can i insert this 3750x in the actual stack?
New
1 30    WS-C3750X-24       12.2(55)SE5           C3750E-UNIVERSALK9-M
Older
1   30     WS-C3750E-24TD     12.2(35)SE5             C3750E-UNIVERSAL-M
2   30     WS-C3750E-24TD     12.2(35)SE5             C3750E-UNIVERSAL-M
I need help
7 Replies 7
Haihua Rong
Hello Juan,
It is as easy as plugging in the cables if you have as minimum ipbase license on the new 3750X.
It won’t work if you have 3750x-24 running with LAN BASE and a 3750x-24 running IPBASE.
I would like to mention that a mixed feature Switch stack is not supported. A Switch Running a LAN Base license can only be stacked with another Switch running LAN Base license only.
Solution:
Purchase an IPBASE license for the 3750x-24 switch.
Workaround: Activate the temporal ipbase license and you will have 8.5 weeks to purchase a permanent.
Following is a link for reference:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_55_se/configuration/guide/swstack.html
Note: We may need to perform an IOS upgrade to the current stack because 12.2(35)SE5 is no longer available in our website.
Haihua
i can then insert the switch into a stack of 3750E 3750E switch, but must have the same version of IOS?
Now these are different machines
  3750X is not the same as 3750E
Hello Juan,
Correct the IOS needs to match to avoid version mismatch. We need to upgrade the currect stack to 12.2(55)SE5 because 12.2(35)SE5 is no longer available for the 3750X switches.
Look for the 3750E products.
Link:
http://software.cisco.com/download/navigator.html?i=!mmd
So i have other question.
i can mixed hardware stack with 3750E and 3750X, but 3750E have a ipservice licence and 3750X have a ipbase licence.
i this case, can i attach the 3750X in 3750E Stack?
Attach show version of 3750E Stack
System image file is "flash:c3750e-universal-mz.122-35.SE5/c3750e-universal-mz.122-35.SE5.bin"
License Level: ipservices   Type: Permanent
Next reboot license Level: ipservices
cisco WS-C3750E-24TD (PowerPC405) processor (revision G0) with 245760K/16376K bytes of memory.
Last reset from power-on
16 Virtual Ethernet interfaces
1 FastEthernet interface
56 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:23:EA:C1:A1:00
Motherboard assembly number     : 73-11177-13
Model revision number           : G0
Motherboard revision number     : A0
Model number                    : WS-C3750E-24TD-E
Daughterboard assembly number   : 800-29737-01
Top Assembly Part Number        : 800-28924-01
Top Assembly Revision Number    : C0
Version ID                      : V03
CLEI Code Number                : COMSE00ARB
Hardware Board Revision Number  : 0x00
Switch   Ports  Model              SW Version              SW Image
*    1   30     WS-C3750E-24TD     12.2(35)SE5             C3750E-UNIVERSAL-M
Switch 02
Switch Uptime                   : 2 years, 39 weeks, 3 days, 15 hours, 58 minutes
Base ethernet MAC Address       : 00:24:C4:CC:5E:80
Top assembly part number        : 800-28924-01
Top assembly revision number    : C0
Version ID                      : V03
License Level                   : ipservices
License Type                    : Permanent
Next reboot licensing Level     : ipservices
Attach show version of 3750X
System image file is "flash:/c3750e-universalk9-mz.122-55.SE5/c3750e-universalk9-mz.122-55.SE5.bin"
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
Base ethernet MAC Address       : 7C:69:F6:C0:71:00
Motherboard assembly number     : 73-12530-10
Model revision number           : A0
Motherboard revision number     : B0
Model number                    : WS-C3750X-24T-S
Daughterboard assembly number   : 800-32727-03
Top Assembly Part Number        : 800-31327-08
Version ID                      : V05
CLEI Code Number                : COMJV00ARE
Hardware Board Revision Number  : 0x05
Hello Juan,
It works. Just take in consideration the next:
The master needs to run the IP services feature set, the master and backup master must be manually configured so that the switches running IP Services feature set have the highest priority to become the stack master and backup master. With this setup, if the master dies, the backup master that takes the master role is also running IP services.
Haihua
so that can i  mixed hardware stack for this case?
3750E (Master) IPservice License 12.2(55)SE5
3750E (Member Backup) IPService License 12.2(55)SE5
3750X (Member) IPBase License 12.2(55)SE5
the tree switches have the same ios version but de 3750X have a IPBase License
Yes.
