commtrans-bpm
Beginner
3750x stacked switches ios upgrade
Hello I am looking for the documentation on upgrading the IOS image on two 3750X switchstack, is it the same process as a 3750 switchstack? I found this link but just want to make sure it applies to the 3750-X model too:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml
1 ACCEPTED SOLUTION
Reza Sharifi
Hall of Fame Expert
Brian,
Upgrade path should be the same since you can have a mix all different type of 3750s together to build a stack.
Here is also a good document:
http://www.ciscosistemi.net/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_55_se/configuration/guide/swstack.pdf
Reza
2 REPLIES 2
Reza Sharifi
Hall of Fame Expert
Brian,
Reza
Leo Laohoo
VIP Community Legend
You can also upgrade and BOOT the IOS via a USB stick.
