3750X Switch Stack Stopped Routing Traffic
Rick Morris
Level 6
Level 6
I have a weird issue that I hope to explain clearly.
Toplogy:
Access----- Dist.---------- Core
3750X ------- 4500X ------- 6509
3750X - 3 switches in stack w/ redundant power supply and ring stack-power configured
4500X - 2 switches in VSS configuration
3750X have 2 uplinks to the Distribution
3570X - 4500X
g1/1/1 - t1/1/7 (uplink 1)
g2/1/1 - t2/1/7 (uplink 2)
Both interfaces are in a Port-Channel configuration.
IP's
3750X     -     4500X     -   6509
10.1.1.3  -     10.1.1.2  -  10.1.1.1
Problem:
3750X stopps passing traffic.  Monitoring software alerts and notifies group of "down" condition.
Unable to traceroute or ping the 3750X
Troubleshooting Steps Taken:
1. Ping 3750X stack - no replies
2. Log into 4500X and ping 3750X - replies
3. SSH to 3750X from 4500X - able to login
4. Ping from 3750X to 4500X - replies
5. Ping from 3750X to 6509 - no replies
6. Checked CPU history - everything is normal
7. Checked temp. - everything normal
8. With constant ping from workstation to 3750X (10.1.1.3)
--Rebooted switch 1,
--after reboot constant ping had no change,
--Also lost ssh connection.
--ssh back into 3750X stack and was able to get back on, verified switch 1 was still rebooting
--No change in status after switch 1 reboot
9.  With constat ping from worskstation to 3750X (10.1.1.3)
--Rebooted switch 1
--after reboot, ping started to reply.
This is the second time this has happen.
The first time I replaced switch 2, verified IOS, swapped stacking cables - so everything is new.
No crash files, no spanning tree issues (that I am aware of), no environmental issues, I have checked fiber and sfp's and found no issues.
For some reason the issue is resolved when we remove switch 2 from the stack every time, well reboot it.
Any ideas?
Reza Sharifi
3570X - 4500X
Are the 3750s connected to the VSS using Etherchannel? What happens if you move the uplink from switch 2 (g2/1/1) to switch 3 (gi3/1/1)?
I have not done that, I guess I could remove the network module from switch 2 and try it.  I doubt it will do anything since switch 1 does not route anything either.
The only time traffic will start passing is when switch two is removed from the stack, well powered down.  I will try to remove it from the stack next time to see if that does anything too.
