3845 router problem
Our 3845 router is frequently getting reboot. After analysis we found the issue as below:
"System returned to ROM by bus error at PC 0x62474E44, address 0xB7B4F6AD at 18:11:36 KSA Mon Oct 24 2011".
We checked the router using command : "Show region" and found the following:
      Start         End     Size(b)  Class  Media  Name
0x0FFFFE00  0x0FFFFFFF         512  Iomem  R/W    BCM region
0x2D800000  0x2FFFFDFF    41942528  Iomem  R/W    iomem
0x60000000  0x6D7FFFFF   226492416  Local  R/W    main
0x6001A0E0  0x644080E3    71229444  IText  R/O    main:text
0x644137E0  0x6740BF9F    50300864  IData  R/W    main:data
0x6740BFA0  0x687E5A9F    20814592  IBss   R/W    main:bss
0x687E5AA0  0x6D7FFFFF    83993952  Local  R/W    main:heap
0x80000000  0x8D7FFFFF   226492416  Local  R/W    main:(main_k0)
0xA0000000  0xAD7FFFFF   226492416  Local  R/W    main:(main_k1)
After working on the output interpreter we found that could be an IOS issue.Let me tell u the IOS version:
" Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)"
Kindly suggest and advice to resolve this issue.
Reza Sharifi
Have a look at this document on how to troubleshot bus crashes. You can also try loading a different release of IOS on your device.  If that does not solve the issue, then you need to open a ticket with TAC and send them the error messages. If it is a hardware issue, you need to RMA it to Cisco for replacement, assuming you have Smartnet contract for it.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800cdd51.shtml
Leo Laohoo
If there is crashinfo file, can you please post them?  If there are more than one, post the last three.
