08-18-2020 05:40 PM
WS-C3850-12X48U running 16.9.5
I added all ports to the Application Visibility enabled column but I'm not seeing any AVC/NBAR data.
Tried rebooting the switch but still no data.
Does it take a while to show up or is there something wrong with my config?
Thanks!
08-18-2020 11:55 PM
it is a bit hard to tell from the GUI screenshots what you are missing, can you post the output of 'sh run' from the CLI ?
Make sure your running config has:
ip http authentication local
ip nbar http-service
08-19-2020 05:17 AM
Just checked the AM and still no data.
Both of those commands are in there.
I can't post the whole config because it's quite lengthy and contains private information.
What I find interesting is "show ip nbar protocol-d top" returns nothing even though every interface has the following:
service-policy input WEBUI-MARKING-IN
service-policy output WEBUI-QUEUING-OUT
ip nbar protocol-discovery
This leads me to believe it's a bug.
08-19-2020 06:58 AM
Since we have asked provide the configuraiton to see is the config applied in right place.
make sure the Interface you applied this NBAR - where you like to monitor AVC
example :
if possible remove other config, provide more related to NABR config.
08-19-2020 07:51 AM
I understand.
I took the time to manually sanitize the config.
Hopefully removed all private information but I probably missed a few things.
Anyway, here it is:
! ! Last configuration change at 08:11:55 EDT Wed Aug 19 2020 by admin ! NVRAM config last updated at 08:13:36 EDT Wed Aug 19 2020 by admin ! version 16.9 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption service call-home no platform punt-keepalive disable-kernel-core ! hostname core3850 ! ! vrf definition Mgmt-vrf ! address-family ipv4 exit-address-family ! address-family ipv6 exit-address-family ! ! aaa new-model ! ! aaa authentication login default local aaa authorization exec default local ! ! ! ! ! ! aaa session-id common clock timezone EST -5 0 clock summer-time EDT recurring switch 1 provision ws-c3850-12x48u ! ! ! ! call-home ! If contact email address in call-home is configured as sch-smart-licensing@cisco.com ! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications. contact-email-addr sch-smart-licensing@cisco.com profile "CiscoTAC-1" active destination transport-method http no destination transport-method email ip routing ! ! ip nbar protocol-pack flash:/pp-adv-cat3k-169.1-34-47.0.0.pack ! ! ! ! ip nbar http-services ! ! ! ip multicast-routing ip dhcp database flash:/dhcp-db.text ip dhcp remember ip dhcp conflict resolution ip dhcp excluded-address XXX.XXX.1.1 XXX.XXX.1.15 ip dhcp excluded-address XXX.XXX.1.200 XXX.XXX.1.254 ip dhcp excluded-address XXX.XXX.10.1 XXX.XXX.10.15 ip dhcp excluded-address XXX.XXX.10.200 XXX.XXX.10.254 ip dhcp excluded-address XXX.XXX.100.1 XXX.XXX.100.5 ip dhcp excluded-address XXX.XXX.100.200 XXX.XXX.100.254 ip dhcp excluded-address XXX.XXX.101.1 XXX.XXX.101.5 ip dhcp excluded-address XXX.XXX.101.200 XXX.XXX.101.254 ! ip dhcp pool VLAN1 network XXX.XXX.1.0 255.255.255.0 default-router XXX.XXX.1.254 option 2 hex ffff.b9b0 dns-server XXX.XXX.10.10 XXX.XXX.10.10 lease 7 ! ip dhcp pool VLAN10 network XXX.XXX.10.0 255.255.255.0 default-router XXX.XXX.10.254 option 2 hex ffff.b9b0 dns-server XXX.XXX.10.10 XXX.XXX.10.10 lease 7 ! ip dhcp pool VLAN100 network XXX.XXX.100.0 255.255.255.0 default-router XXX.XXX.100.254 option 2 hex ffff.b9b0 dns-server XXX.XXX.10.10 XXX.XXX.10.10 lease 7 ! ip dhcp pool VLAN101 network XXX.XXX.101.0 255.255.255.0 default-router XXX.XXX.101.254 option 2 hex ffff.b9b0 dns-server XXX.XXX.10.10 XXX.XXX.10.10 lease 7 ! ! ! ip igmp snooping querier login on-success log ipv6 unicast-routing ipv6 mld snooping ipv6 dhcp database flash:/dhcpv6-db.text ipv6 dhcp pool VLAN1 address prefix XXXX:XXX:XXXX:1::/64 dns-server XXXX:XXX:XXXX:10::10 ! ipv6 dhcp pool VLAN10 address prefix XXXX:XXX:XXXX:10::/64 dns-server XXXX:XXX:XXXX:10::10 ! ipv6 dhcp pool VLAN100 address prefix XXXX:XXX:XXXX:100::/64 dns-server XXXX:XXX:XXXX:10::10 domain-name djxmmx.net ! ipv6 dhcp pool VLAN101 address prefix XXXX:XXX:XXXX:101::/64 dns-server XXXX:XXX:XXXX:10::10 ! ipv6 multicast-routing ! ! ! ! ! ! ! vtp mode transparent ! crypto pki trustpoint TP-self-signed-447615806 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-447615806 revocation-check none rsakeypair TP-self-signed-447615806 ! crypto pki trustpoint SLA-TrustPoint enrollment terminal revocation-check crl ! crypto pki trustpoint Certificate enrollment pkcs12 revocation-check crl rsakeypair Certificate ! crypto pki trustpoint Certificate-rrr1 revocation-check crl ! ! crypto pki certificate chain TP-self-signed-447615806 certificate self-signed 01 nvram:IOS-Self-Sig#2.cer crypto pki certificate chain SLA-TrustPoint certificate ca 01 nvram:CiscoLicensi#1CA.cer crypto pki certificate chain Certificate certificate 610259E00CB10F84E71699B005F07108 nvram:SectigoRSADo#7108.cer certificate ca 7D5B5126B476BA11DB74160BBC530DA7 nvram:USERTrustRSA#DA7CA.cer crypto pki certificate chain Certificate-rrr1 certificate ca 01FD6D30FCA3CA51A81BBC640E35032D nvram:USERTrustRSA#32DCA.cer ! crypto pki certificate pool cabundle nvram:ios_core.p7b ! system mtu 9198 license boot level ipservicesk9 ! ! diagnostic bootup level minimal ! spanning-tree mode rapid-pvst spanning-tree loopguard default spanning-tree extend system-id spanning-tree vlan 1-4094 priority 24576 ! errdisable recovery cause udld errdisable recovery cause bpduguard errdisable recovery cause security-violation errdisable recovery cause channel-misconfig errdisable recovery cause pagp-flap errdisable recovery cause dtp-flap errdisable recovery cause link-flap errdisable recovery cause sfp-config-mismatch errdisable recovery cause gbic-invalid errdisable recovery cause l2ptguard errdisable recovery cause psecure-violation errdisable recovery cause port-mode-failure errdisable recovery cause dhcp-rate-limit errdisable recovery cause pppoe-ia-rate-limit errdisable recovery cause mac-limit errdisable recovery cause vmps errdisable recovery cause storm-control errdisable recovery cause inline-power errdisable recovery cause arp-inspection errdisable recovery cause link-monitor-failure errdisable recovery cause oam-remote-failure errdisable recovery cause loopback errdisable recovery cause psp ! ! redundancy mode sso ! ! ! ! ! transceiver type all monitoring ! vlan 10,100-101,4094 lldp run ! ! class-map match-all WEBUI-BROADCAST_VIDEO-NBAR match protocol attribute traffic-class broadcast-video match protocol attribute business-relevance business-relevant class-map match-any system-cpp-police-topology-control description Topology control class-map match-any system-cpp-police-sw-forward description Sw forwarding, L2 LVX data, LOGGING class-map match-all WEBUI-VOICE-NBAR match protocol attribute traffic-class voip-telephony match protocol attribute business-relevance business-relevant class-map match-all WEBUI-BULK_DATA-NBAR match protocol attribute traffic-class bulk-data match protocol attribute business-relevance business-relevant class-map match-any system-cpp-default description Inter FED, EWLC control, EWLC data class-map match-all WEBUI-SIGNALING-NBAR match protocol attribute traffic-class signaling match protocol attribute business-relevance business-relevant class-map match-any WEBUI-NETWORK_CONTROL-DSCP match dscp cs2 match dscp cs3 match dscp cs6 match dscp cs7 class-map match-all WEBUI-SCAVENGER-NBAR match protocol attribute business-relevance business-irrelevant class-map match-any system-cpp-police-sys-data description Learning cache ovfl, High Rate App, Exception, EGR Exception, NFL SAMPLED DATA, RPF Failed class-map match-any WEBUI-SCAVENGER-DSCP match dscp cs1 class-map match-all WEBUI-NETWORK_CONTROL-NBAR match protocol attribute traffic-class network-control match protocol attribute business-relevance business-relevant class-map match-any WEBUI-BULK_DATA-DSCP match dscp af11 match dscp af12 match dscp af13 class-map match-any WEBUI-BROADCAST_VIDEO-DSCP match dscp cs4 match dscp af41 match dscp af42 match dscp af43 match dscp cs5 class-map match-all WEBUI-MULTIMEDIA_CONFERENCING-NBAR match protocol attribute traffic-class multimedia-conferencing match protocol attribute business-relevance business-relevant class-map match-any system-cpp-police-punt-webauth description Punt Webauth class-map match-any WEBUI-VOICE-DSCP match dscp ef class-map match-any system-cpp-police-l2lvx-control description L2 LVX control packets class-map match-any system-cpp-police-forus description Forus Address resolution and Forus traffic class-map match-any system-cpp-police-multicast-end-station description MCAST END STATION class-map match-any system-cpp-police-multicast description Transit Traffic and MCAST Data class-map match-all WEBUI-NETWORK_MANAGEMENT-NBAR match protocol attribute traffic-class ops-admin-mgmt match protocol attribute business-relevance business-relevant class-map match-any system-cpp-police-l2-control description L2 control class-map match-any system-cpp-police-dot1x-auth description DOT1X Auth class-map match-any WEBUI-MULTIMEDIA_STREAMING-DSCP match dscp af31 match dscp af32 match dscp af33 class-map match-any system-cpp-police-data description ICMP redirect, ICMP_GEN and BROADCAST class-map match-all WEBUI-REALTIME_INTERACTIVE-NBAR match protocol attribute traffic-class real-time-interactive match protocol attribute business-relevance business-relevant class-map match-any WEBUI-TRANSACTIONAL_DATA-DSCP match dscp af21 match dscp af22 match dscp af23 class-map match-any system-cpp-police-stackwise-virt-control description Stackwise Virtual class-map match-all WEBUI-TRANSACTIONAL_DATA-NBAR match protocol attribute traffic-class transactional-data match protocol attribute business-relevance business-relevant class-map match-any system-cpp-police-control-low-priority description General punt class-map match-any non-client-nrt-class class-map match-all WEBUI-MULTIMEDIA_STREAMING-NBAR match protocol attribute traffic-class multimedia-streaming match protocol attribute business-relevance business-relevant class-map match-any system-cpp-police-routing-control description Routing control and Low Latency class-map match-any system-cpp-police-protocol-snooping description Protocol snooping class-map match-any system-cpp-police-dhcp-snooping description DHCP snooping class-map match-any system-cpp-police-system-critical description System Critical and Gold Pkt ! policy-map WEBUI-MARKING-IN class WEBUI-VOICE-NBAR set dscp ef class WEBUI-BROADCAST_VIDEO-NBAR set dscp cs5 class WEBUI-REALTIME_INTERACTIVE-NBAR set dscp cs4 class WEBUI-MULTIMEDIA_CONFERENCING-NBAR set dscp af41 class WEBUI-MULTIMEDIA_STREAMING-NBAR set dscp af31 class WEBUI-SIGNALING-NBAR set dscp cs3 class WEBUI-NETWORK_CONTROL-NBAR set dscp cs6 class WEBUI-NETWORK_MANAGEMENT-NBAR set dscp cs2 class WEBUI-TRANSACTIONAL_DATA-NBAR set dscp af21 class WEBUI-BULK_DATA-NBAR set dscp af11 class WEBUI-SCAVENGER-NBAR set dscp cs1 class class-default set dscp default policy-map system-cpp-policy class system-cpp-police-control-low-priority policy-map WEBUI-QUEUING-OUT class WEBUI-VOICE-DSCP priority level 1 percent 1 queue-buffers ratio 5 class WEBUI-BROADCAST_VIDEO-DSCP priority level 2 percent 30 queue-buffers ratio 5 class WEBUI-NETWORK_CONTROL-DSCP bandwidth remaining percent 10 queue-buffers ratio 5 class WEBUI-MULTIMEDIA_STREAMING-DSCP bandwidth remaining percent 20 queue-buffers ratio 10 queue-limit dscp af33 percent 80 queue-limit dscp af32 percent 90 queue-limit dscp af31 percent 100 class WEBUI-TRANSACTIONAL_DATA-DSCP bandwidth remaining percent 20 queue-buffers ratio 10 queue-limit dscp af23 percent 80 queue-limit dscp af22 percent 90 queue-limit dscp af21 percent 100 class WEBUI-BULK_DATA-DSCP bandwidth remaining percent 14 queue-buffers ratio 20 queue-limit dscp af13 percent 80 queue-limit dscp af12 percent 90 queue-limit dscp af11 percent 100 class WEBUI-SCAVENGER-DSCP bandwidth remaining percent 1 queue-buffers ratio 5 class class-default bandwidth remaining percent 35 queue-buffers ratio 40 ! ! ! ! ! ! ! ! ! ! ! interface Port-channel1 description VLAN 1 - SonicWall switchport mode access ! interface Port-channel2 description VLAN 10 switchport access vlan 10 switchport mode access spanning-tree portfast ! interface GigabitEthernet0/0 vrf forwarding Mgmt-vrf ip address 192.168.0.254 255.255.255.0 negotiation auto ! interface GigabitEthernet1/0/1 description LAG - SonicWall switchport mode access channel-group 1 mode on service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/2 description LAG - SonicWall switchport mode access channel-group 1 mode on service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/3 description LACP switchport access vlan 10 switchport mode access channel-group 2 mode active spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/4 description LACP switchport access vlan 10 switchport mode access channel-group 2 mode active spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/5 description VLAN 10 switchport access vlan 10 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/6 description VLAN 10 switchport access vlan 10 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/7 description VLAN 10 switchport access vlan 10 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/8 description VLAN 10 switchport access vlan 10 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/9 description VLAN 10 switchport access vlan 10 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/10 description VLAN 10 switchport access vlan 10 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/11 description VLAN 10 switchport access vlan 10 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/12 description VLAN 10 switchport access vlan 10 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/13 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/14 description VLAN 1 - Lexmark MC3426 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/15 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/16 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/17 description VLAN 101 - Polaris Z3 switchport access vlan 101 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/18 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/19 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/20 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/21 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/22 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/23 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/24 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/25 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/26 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/27 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/28 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/29 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/30 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/31 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/32 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/33 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/34 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/35 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/0/36 description VLAN 100 switchport access vlan 100 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/0/37 description TRUNK - Cisco AP3802 switchport mode trunk service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/0/38 description VLAN 10 switchport access vlan 10 switchport mode access spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/0/39 description TRUNK switchport mode trunk spanning-tree portfast service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/0/40 description VLAN 1 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/0/41 description VLAN 1 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/0/42 description VLAN 1 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/0/43 description VLAN 1 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/0/44 description VLAN 1 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/0/45 description VLAN 1 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/0/46 description VLAN 1 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/0/47 description VLAN 1 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/0/48 description VLAN 1 switchport mode access service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/1/1 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/1/2 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/1/3 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface GigabitEthernet1/1/4 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/1/1 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/1/2 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/1/3 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/1/4 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/1/5 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/1/6 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/1/7 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface TenGigabitEthernet1/1/8 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface FortyGigabitEthernet1/1/1 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface FortyGigabitEthernet1/1/2 service-policy input WEBUI-MARKING-IN service-policy output WEBUI-QUEUING-OUT ip nbar protocol-discovery ! interface Vlan1 description VLAN 1 ip address XXX.XXX.1.254 255.255.255.0 ip helper-address XXX.XXX.10.255 ip helper-address XXX.XXX.100.255 ip directed-broadcast ip pim sparse-dense-mode ip igmp version 3 ipv6 address XXXX:XXX:XXXX:1:FFFF:FFFF:FFFF:FF7F/64 ipv6 nd prefix XXXX:XXX:XXXX:1::/64 2592000 604800 no-autoconfig ipv6 nd managed-config-flag ipv6 nd other-config-flag ipv6 nd router-preference High ipv6 nd ra dns server XXXX:XXX:XXXX:10::10 604800 ipv6 dhcp server VLAN1 ! interface Vlan10 description VLAN 10 ip address XXX.XXX.10.254 255.255.255.0 ip helper-address XXX.XXX.1.255 ip helper-address XXX.XXX.100.255 ip directed-broadcast ip pim sparse-dense-mode ip igmp version 3 ipv6 address XXXX:XXX:XXXX:10:FFFF:FFFF:FFFF:FF7F/64 ipv6 nd prefix XXXX:XXX:XXXX:10::/64 2592000 604800 no-autoconfig ipv6 nd managed-config-flag ipv6 nd other-config-flag ipv6 nd router-preference High ipv6 nd ra dns server XXXX:XXX:XXXX:10::10 604800 ipv6 dhcp server VLAN10 ! interface Vlan100 description VLAN 100 ip address XXX.XXX.100.254 255.255.255.0 ip helper-address XXX.XXX.1.255 ip helper-address XXX.XXX.10.255 ip directed-broadcast ip pim sparse-dense-mode ip igmp version 3 ipv6 address XXXX:XXX:XXXX:100:FFFF:FFFF:FFFF:FF7F/64 ipv6 nd prefix XXXX:XXX:XXXX:100::/64 2592000 604800 ipv6 nd managed-config-flag ipv6 nd other-config-flag ipv6 nd router-preference High ipv6 nd ra dns server XXXX:XXX:XXXX:10::10 604800 ipv6 dhcp server VLAN100 ! interface Vlan101 description VLAN 101 ip address XXX.XXX.101.254 255.255.255.0 ip access-group VLAN101-IPv4-In in ip access-group VLAN101-IPv4-Out out ip igmp version 3 ipv6 address XXXX:XXX:XXXX:101:FFFF:FFFF:FFFF:FF7F/64 ipv6 nd prefix XXXX:XXX:XXXX:101::/64 2592000 604800 ipv6 nd managed-config-flag ipv6 nd other-config-flag ipv6 nd router-preference High ipv6 nd ra dns server XXXX:XXX:XXXX:10::10 604800 ipv6 dhcp server VLAN101 ipv6 traffic-filter VLAN101-IPv6-In in ipv6 traffic-filter VLAN101-IPv6-Out out ! ip forward-protocol nd ip forward-protocol udp echo ip forward-protocol udp discard ip forward-protocol udp 1900 ip forward-protocol udp 3074 ip forward-protocol udp 3702 ip forward-protocol udp 4000 ip forward-protocol udp 12203 ip forward-protocol udp 13203 ip forward-protocol udp 27960 ip forward-protocol udp 27961 ip forward-protocol udp 27962 ip forward-protocol udp 28960 ip forward-protocol udp 28961 ip forward-protocol udp 28962 ip forward-protocol udp 28963 ip forward-protocol udp 28964 ip forward-protocol udp 28965 ip http server ip http authentication local ip http secure-server ip http secure-trustpoint Certificate ip route 0.0.0.0 0.0.0.0 Vlan1 XXX.XXX.1.1 ip ssh version 2 ! ! ip access-list extended VLAN101-IPv4-In permit tcp XXX.XXX.101.0 0.0.0.255 XXX.XXX.10.0 0.0.0.255 eq domain permit tcp XXX.XXX.101.0 0.0.0.255 XXX.XXX.10.0 0.0.0.255 eq www permit tcp XXX.XXX.101.0 0.0.0.255 XXX.XXX.10.0 0.0.0.255 eq 443 permit udp XXX.XXX.101.0 0.0.0.255 XXX.XXX.10.0 0.0.0.255 eq domain permit tcp XXX.XXX.101.0 0.0.0.255 XXX.XXX.10.0 0.0.0.255 eq domain permit tcp XXX.XXX.101.0 0.0.0.255 XXX.XXX.10.0 0.0.0.255 eq www permit tcp XXX.XXX.101.0 0.0.0.255 XXX.XXX.10.0 0.0.0.255 eq 443 permit udp XXX.XXX.101.0 0.0.0.255 XXX.XXX.10.0 0.0.0.255 eq domain deny ip XXX.XXX.101.0 0.0.0.255 XXX.XXX.1.0 0.0.0.255 deny ip XXX.XXX.101.0 0.0.0.255 XXX.XXX.2.0 0.0.0.255 deny ip XXX.XXX.101.0 0.0.0.255 XXX.XXX.10.0 0.0.0.255 deny ip XXX.XXX.101.0 0.0.0.255 XXX.XXX.100.0 0.0.0.255 deny ip XXX.XXX.101.0 0.0.0.255 XXX.XXX.1.0 0.0.0.255 deny ip XXX.XXX.101.0 0.0.0.255 XXX.XXX.2.0 0.0.0.255 deny ip XXX.XXX.101.0 0.0.0.255 XXX.XXX.10.0 0.0.0.255 deny ip XXX.XXX.101.0 0.0.0.255 XXX.XXX.100.0 0.0.0.255 permit ip any any ip access-list extended VLAN101-IPv4-Out permit tcp XXX.XXX.10.0 0.0.0.255 eq domain XXX.XXX.101.0 0.0.0.255 permit tcp XXX.XXX.10.0 0.0.0.255 eq www XXX.XXX.101.0 0.0.0.255 permit tcp XXX.XXX.10.0 0.0.0.255 eq 443 XXX.XXX.101.0 0.0.0.255 permit udp XXX.XXX.10.0 0.0.0.255 eq domain XXX.XXX.101.0 0.0.0.255 permit tcp XXX.XXX.10.0 0.0.0.255 eq domain XXX.XXX.101.0 0.0.0.255 permit tcp XXX.XXX.10.0 0.0.0.255 eq www XXX.XXX.101.0 0.0.0.255 permit tcp XXX.XXX.10.0 0.0.0.255 eq 443 XXX.XXX.101.0 0.0.0.255 permit udp XXX.XXX.10.0 0.0.0.255 eq domain XXX.XXX.101.0 0.0.0.255 deny ip XXX.XXX.1.0 0.0.0.255 XXX.XXX.101.0 0.0.0.255 deny ip XXX.XXX.2.0 0.0.0.255 XXX.XXX.101.0 0.0.0.255 deny ip XXX.XXX.10.0 0.0.0.255 XXX.XXX.101.0 0.0.0.255 deny ip XXX.XXX.100.0 0.0.0.255 XXX.XXX.101.0 0.0.0.255 deny ip XXX.XXX.1.0 0.0.0.255 XXX.XXX.101.0 0.0.0.255 deny ip XXX.XXX.2.0 0.0.0.255 XXX.XXX.101.0 0.0.0.255 deny ip XXX.XXX.10.0 0.0.0.255 XXX.XXX.101.0 0.0.0.255 deny ip XXX.XXX.100.0 0.0.0.255 XXX.XXX.101.0 0.0.0.255 permit ip any any ! ipv6 route ::/0 Vlan1 XXXX::XXXX:XXXX:XXXX:5A1A ! ! snmp-server group ReadOnly v3 priv read ReadView snmp-server view ReadView internet included snmp-server location snmp-server contact ! ! ! ipv6 access-list VLAN101-IPv6-In permit tcp XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:10::/64 eq domain permit tcp XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:10::/64 eq www permit tcp XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:10::/64 eq 443 permit udp XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:10::/64 eq domain permit tcp XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:10::/64 eq domain permit tcp XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:10::/64 eq www permit tcp XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:10::/64 eq 443 permit udp XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:10::/64 eq domain deny ipv6 XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:1::/64 deny ipv6 XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:2::/64 deny ipv6 XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:10::/64 deny ipv6 XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:100::/64 deny ipv6 XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:1::/64 deny ipv6 XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:2::/64 deny ipv6 XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:10::/64 deny ipv6 XXXX:XXX:XXXX:101::/64 XXXX:XXX:XXXX:100::/64 permit ipv6 any any ! ipv6 access-list VLAN101-IPv6-Out permit tcp XXXX:XXX:XXXX:10::/64 eq domain XXXX:XXX:XXXX:101::/64 permit tcp XXXX:XXX:XXXX:10::/64 eq www XXXX:XXX:XXXX:101::/64 permit tcp XXXX:XXX:XXXX:10::/64 eq 443 XXXX:XXX:XXXX:101::/64 permit udp XXXX:XXX:XXXX:10::/64 eq domain XXXX:XXX:XXXX:101::/64 permit tcp XXXX:XXX:XXXX:10::/64 eq domain XXXX:XXX:XXXX:101::/64 permit tcp XXXX:XXX:XXXX:10::/64 eq www XXXX:XXX:XXXX:101::/64 permit tcp XXXX:XXX:XXXX:10::/64 eq 443 XXXX:XXX:XXXX:101::/64 permit udp XXXX:XXX:XXXX:10::/64 eq domain XXXX:XXX:XXXX:101::/64 deny ipv6 XXXX:XXX:XXXX:1::/64 XXXX:XXX:XXXX:101::/64 deny ipv6 XXXX:XXX:XXXX:2::/64 XXXX:XXX:XXXX:101::/64 deny ipv6 XXXX:XXX:XXXX:10::/64 XXXX:XXX:XXXX:101::/64 deny ipv6 XXXX:XXX:XXXX:100::/64 XXXX:XXX:XXXX:101::/64 deny ipv6 XXXX:XXX:XXXX:1::/64 XXXX:XXX:XXXX:101::/64 deny ipv6 XXXX:XXX:XXXX:2::/64 XXXX:XXX:XXXX:101::/64 deny ipv6 XXXX:XXX:XXXX:10::/64 XXXX:XXX:XXXX:101::/64 deny ipv6 XXXX:XXX:XXXX:100::/64 XXXX:XXX:XXXX:101::/64 permit ipv6 any any ! control-plane service-policy input system-cpp-policy ! banner motd Authorized Access Only This system is the property of UNAUTHORIZED ACCESS TO THIS DEVICE IS PROHIBITED. You must have explicit permission to access this device. All activities performed on this device are logged. ! line con 0 logging synchronous stopbits 1 line aux 0 stopbits 1 line vty 0 4 logging synchronous transport preferred ssh transport input ssh transport output ssh line vty 5 97 logging synchronous transport preferred ssh transport input ssh transport output ssh ! ntp server XXXX:XXX:XXXX:10::10 ntp server XXXX:XXX:XXXX:10::10 ntp server XXX.XXX.10.10 ntp server XXX.XXX.10.10 ! ! ! ! ! ! end
Hopefully I'm just missing something simple.
Thanks!
08-20-2020 05:45 AM
Ping
