Highlighted
Beginner
3850 Switches Default QOS
I see the 3850 switches all have this class-map and the qos queue-softmax command and was wondering if this is the default for 3850 switches. We are not doing QOS on any of our 3850s but wanted to check if this is needed. Thanks.
qos queue-softmax-multiplier 100
class-map match-any non-client-nrt-class
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
1 ACCEPTED SOLUTION
Highlighted
VIP Expert
neither of these commands are in there by default, so somebody must have manually put them in there. The class-map/policy-map part is identical to an example used in the document below, that is probably where it is derived from. Either way, if you don't need these, you can safely remove them...
QoS Configuration Guide, Cisco IOS XE Release 3SE (Catalyst 3850 Switches)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/qos/configuration_guide/b_qos_3se_3850_cg/b_qos_3se_3850_cg_chapter_011.html
3 REPLIES 3
Highlighted
VIP Expert
Highlighted
Thank you Georg for the quick response. I will go ahead and remove them.
Highlighted
That is not right, On my 3850 with Fuji 16.9.4 firmware there is this configuration out of the stock on the router!
Content for Community-Ad
