Showing results forĀ
Search instead forĀ
Did you mean:Ā
4000 Cisco rommon problem
ltjames1934
I have a Catalyst 4006 siries  4000 I can't seem to get out of Rommon I have searched everything I can online and have found a lot of commands but when I put them in it gives me a bad command error.Any Ideas of what to try.
12 Replies 12
glen.grant
  If its at rommon  do a dir bootflash:  and see if there is a actual catos file in there . If so just issue a boot bootflash:  and see if it will load .  This should help , read thru it specially the cat 4000 section .
http://www.cisco.com/en/US/partner/products/hw/switches/ps663/products_tech_note09186a00800949c3.shtml
I followed the steps as per the link you sent I got this error
Input redirection is not supported at this level
the message i get following the directions from the link
ltjames1934
I did the dir bootflash it came up saying bad divice name.
Try giving a "reset" and see if it helps.
-Sweta
could you pls try the below steps,
rommon> priv
rommon>dev  >>> the output of this command will show you the list of file systems present
Based on that you can try accessing the memory device.
if the internal memory device is not accessible, then try booting the device from an external flash.
dir disk0:
useful commands:
rommon> sync  >> used to save the configs
rommon> BOOT=  >> clearing the present boot variable.
rommon> BOOT= setting the boot variable
rommon>set  >> output of this command will list you the present boot variable configured, configuration register etc.
Dont forget to do a sync after configuring the boot variable & configuration register.
You can try xmodem recovery in the rommon as well.
Cheers
Somu
Rate helpful posts
0:00.578919: Please set IPAddr variable
0:00.579585: Please set Netmask variable
0:00.580038: Please set Broadcast variable
0:00.580492: No gateway has been specified
0:00.581067: Network is not configured
WS-X4013 bootrom version 5.4(1), built on 2000.04.04 10:48:54
H/W Revisions:    Crumb: 5    Rancor: 8    Board: 2
Supervisor MAC addresses: 00:06:d7:ea:55:00 through 00:06:d7:ea:58:ff (1024 addr
esses)
Installed memory: 64 MB
Testing LEDs.... done!
rommon 1 >
rommon 1 >priv
rommon 2 >dev
Devices in device table:
        id  name
bootflash:  boot flash
      tmp:  tmp fs
rommon 3 >boot
loadprog: bad file magic number:        0
boot: cannot load "bootflash:FL3AS1.cfg"
boot failed.
rommon 5 >set
PS1=rommon ! >
TftpServer=10.1.1.1
vitTimeouts=9
MemorySize=64
ResetCause=20
TmpfsAddr=2197815296
TmpfsSize=12582912
TmpfsDirectorySize=10240
DiagFreePageLimit=12288
AutobootStatus=fail
DiagBootMode=post
?=0
ROMVERSION=5.4(1)
WHICHBOOT=bootflash:FL3AS1.cfg
rommon 1 >priv
rommon 2 >dev
        id  name
      tmp:  tmp fs
rommon 3 >boot
boot failed.
rommon 5 >set
PS1=rommon ! >
TftpServer=10.1.1.1
vitTimeouts=9
MemorySize=64
ResetCause=20
TmpfsSize=12582912
AutobootStatus=fail
DiagBootMode=post
?=0
ROMVERSION=5.4(1)
This is killing me HELP!
Did you try "reset"???
rommon 15 >reset
0:00.578950: Please set IPAddr variable
0:00.579618: Please set Netmask variable
0:00.580070: Please set Broadcast variable
0:00.580521: No gateway has been specified
0:00.581100: Network is not configured
esses)
rommon 1 > rommon 15 >reset
esses)
rommon 1 >
yes i have several times
Your IOS is corrupt.
Can you advise me on how to find and reload the IOS software?
