404 not found
Hello could you help me with this error help me with this error it does not let me enter the web console because I was trying to put a backup where it was not and now I can not get it to run the web error is 404 not found I have the switch catalyst 2960-X and here I leave a picture of my CLI witch the command "dir" executed.
Thanks.
2 Accepted Solutions
it doesn't work for me
no entiendo lo que quieres que haga
29 Replies 29
balaji.bandi
If you like to access Switch GUI, you need to have correct IOS installed with Packages.
post  output ( also your attachment is missing here ?)
show version
show run
dir
BB
post show run or check below config enable : (  you also need secure certs keys)
ip http secure-server
try below example :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/https/configuration/12-2sy/https-12-2sy-book/nm-http-web.html
BB
but have you understood why this has happened to me
I accidentally hit the solution button
not sure we understood your question here ?  - is this working before ? or it never worked ? or is this not working for you only ?
to know what is configured we need below information :
show version
show run
dir
BB
that's it
That input not going to help what is configured on the device (do type below commands on the device and post here).
show version
show run
BB
how did you pull this config, using SSH ? or from console ?
what is  device IP from you are accessing ?  Are you able to ping the IP address of switch  10.10.0.2 ?
BB
How did you get this configuration using SSH? or from the console?
From the console because the ssh does not work for me either
What IP of the device are you accessing?
10.10.0.2
Can you ping the switch IP address 10.10.0.2?
Yes
