40G VSS Link Case
Hummelbrunner
Beginner
Beginner
i have a customer which has two Catalyst 6807 which we use as Core equipment.
The two Catalyst 6807 are each of them running with one Supervisor Engine SUP-2T.
Between the two Catalyst 6807 we have a 2x10G VSS Link. We want to increase the VSS Link from 10G to 40G.
In the Catalysts we have in each of the Catalysts one C6800-8P40G module.
I have no chance to change the catalysts from a commercial point of view.
So we have to increase from 2x10G to 2x40G over the 40G modules.
I know that it is not recommended by Cisco, but does this mean that it is technical impossible ?
If it is technical impossible why is it not recommended ?
What are the risks to do it that way ?
2 REPLIES 2
balaji.bandi
VIP Guru VIP Guru
VIP Guru
I have not seen any Limitation using 40GB link, i am sure 40GB supporr for VSS link
refer below guide  :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-1SY/config_guide/sup2T/15_1_sy_swcg_2T/virtual_switching_systems.html
BB
Reza Sharifi
Hall of Fame Expert Hall of Fame Expert
Hall of Fame Expert
According to the datasheet (see table-1), both XL and non-XL modules can be used to form VSS.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6800-series-switches/datasheet-c78-739155.html
