ā06-14-2012 05:47 AM - edited ā03-07-2019 07:15 AM
We own several WS-C4506 with Supervisor II+ running IOS image 4500-ipbase-mz.122-31.SGA6.bin,
i want to utilize the mgmt port for out-of-band management but i can't find it on the interface list.
Does anyone know how to activate and configure this port?
Cheers,
Talm M
Solved! Go to Solution.
ā06-14-2012 06:06 AM
hi Talm,
Sorry - accidently deleted prevous post to your question.
The Ethernet management port can be used (in ROMMON mode only) to recover a switch software image that has been corrupted or destroyed due to a network catastrophe. When using Cisco IOS Release 12.2(50)SG or later, this port can also perform the same functions as the console port. For earlier Cisco IOS software releases, this port is not active while the switch is operating normally.
For 12.2(50)SG and later releases, please see the configuration guidelines:
Kind Regards,
Ivan
**Please grade this post if you find it useful.
hi Talm,
Kind Regards,
Ivan
