4500 POE Modules
regodin
Are there any disadvantages to using an older WS-X4548-GB-RJ45V module in a 4500E chassis?
Leo Laohoo
Depends on what you are planning to do.
This line card provide up to 15.4w PoE.  So if you need to power up something like 20.0w (802.3at) this line card may not be sufficient.  Otherwise, it's fine.
Make sure you have the right amount of power supply.
