4500 Switch usage
smartboy2255
HI all,
How to see the backplane usage of cisco 4500 switch through command..
Thanks a lot in advance
Ajith
Somasundaram Jayaraman
++ In 4500 switches there is no fabric and it's centralized forwarding .
++ The 4500 Switch-Architecture is such that all the Line cards are connected to the centralized ASIC in the Supervisor ++ Unfortunately there is no command to show the utilization of the backplane of the 4500  chassis because of the way the architecture of the chassis .
++ Each line module has a direct link to the supervisor modules. So if you have 2 supervisor modules, each of the 6 line cards have access to a 6Gb full duplex connection to the supervisors which can handle 96Gbps bandwidth ++ Also the Catalyst 4000 (IOS) does not support CISCO-STACK-MIB. Therefore, it is not possible to monitor backplane utilization on the Cat4000 IOS via SNMP.
Hope this answers your questions.
Cheers
Somu
Rate helpful posts
