01-30-2015 08:09 AM - edited 03-07-2019 10:26 PM
I need to factory default a pair of 4500 switches in VSS mode.
This is how I plan to do it.
1. on switch 1 execute redundancy force-switchover
2. write erase on the switch 2 and reload
3. this should failover to switch 1
4. write erase in switch 1
Is there anything I missed? Should I remove
Maybe I should do a switch convert mode stand-alone on both switches and then do a write erase on both?
01-30-2015 05:30 PM
1. Configure the config-registry to 0x2101. Reboot the entire chassis.
2. Once the chassis reboot, both cards should boot up without reading the startup-config file.
3. Go into configuration mode and change the config-registry to 0x2102.
4. Exit configuration mode and erase the configuration using the command "wr erase".
5. Don't forget to delete the VLAN.dat file.
01-31-2015 12:31 AM
Dear Leo,
I tried setting the switch to factory reset, however i could see the VSS config file saved in the bootflash, i deleted the same, however switch started again in VSS mode, i had to convert it into standalone mode for the switch to exit from VSS
01-31-2015 06:26 AM
You have to convert the chassis to stand-alone mode before erasing the configs, if not the all the VSS config/changes will stay.
07-25-2023 01:41 PM
Hi Reza, what's the commands to convert the chassis to a stand-alone?
