4500x Switch 100FX SFP Compatibility
NPT_2
Level 2
Level 2
We have a couple WS-C4500X-32 Switches with 32 SFP+ ports.  I recall previous release notes showing support for the GLC-GE-100FX SFP modules.  However, the latest SFP release notes don't show any support for the 100FX modules and when I plug in a GLC-GE-100FX SFP it shows up as unknown SFP+.
Is there any way to support a 100FX module in the 4500X Switches or will I have to use a media converter to convert to 100FX from a GLC-T SFP?
Jim
Reza Sharifi
According to this comparability matrix it is supported (see link) as long as you are running IOS 3.8.0E.  If not after inserting the optic can you set the speed on that port to 100 and test again?
If none of these works than media converter maybe the only way.
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/100MB_Tx_Matrix.html
5 Replies 5
Reza Sharifi
Thanks for the info.  I'm only at 3.04.05.SG.151-2.SG5 so it looks like I'll have to upgrade.
I'll try a newer version and see if that takes care of the issue.  I was looking at the main transceiver (not 100 Mbit Transceiver) matrix and it didn't show the 100FX modules for the 4500x, this must have been what I was previously looking at.
Any recommendations for a good stable version 3.8.0E or Higher?
I have been running 03.07.00.E for the last couple of years with no issues, but this will not help you since it is older than 3.8.
Looking at Cisco Web site, there seem to be only one option and that is version 03.09.01 available for download.
cat4500e-universal.SPA.03.09.01.E.152-5.E1.bin
Its an ED version and it was just released.
I would say, try it and keep an eye on the box to make sure you are not running to any issues.
If it is stable for a few months than you are good to go.
The latest 3.09 software seems to be working and picking up the 100FX SFP without issues.  I'll continue to monitor for stability and keep an eye out for any newer 3.09 releases for bug fixes as they come out.
Good to know the new software is enabling the 100FX SFP.
