4500X Upgrade from 03.08.07.E to 3.11.3aE
suarej
Beginner
Beginner
Hi everyone, I am upgrading a pair of 4500X in VSS from 3.08 to 3.11, rommon version is "15.0(1r)SG12" I did not see anything in the release notes, that would stop me from doing the upgrade, I am planning to do the following steps.
ActionCommand
Backup current IOScopy bootflash: tftp:
Copy new IOScopy tftp: bootflash:IMAGE
 copy bootflash: slavebootflash:IMAGE
Verifydir bootflash:
 dir slavebootflash:
Verify MD5 Hashverify /md5 bootflash:IMAGE
 verify /md5 slavebootflash:IMAGE
Remove current Boot SystemConfigure terminal no boot system flash bootflash:IMAGE
Verifyshow bootvar Seen in show tech -- register 0x2102
Set new imageConfigure terminal
 boot system flash slavebootflash:IMAGE
Save configurationwrite
Reload both Master and Slave
redundancy reload shelf
Does anyone with more experience see anything wrong or am I missing anything?
7 Replies 7
balaji.bandi
VIP Community Legend VIP Community Legend
yes, high-level steps are good.
just follow below thread :
https://community.cisco.com/t5/switching/4500x-upgrade-path-from-3-6-7-to-3-11-recommendation/td-p/4005179
BB
Thanks, yes I am running SG11 so no need to upgrade the ROMMON.
balaji.bandi
you do not require.
BB
Do you have any experience with the boot system having to specify the slavebootflash and bootflash? or is just setting up bootflash is enough for both?
 no boo system bootflash:old_ios.bin
 boot system bootflash:ROMMON_filename
 boot system bootflash:NEW_IOS_filename.bin
 boot system bootflash:OLD_IOS_filename.bin
balaji.bandi
VSS you need to use copying files active bootflash: (primary) you can copy from bootflash to slavebootflash: (this is secondary device)
Boot variable only bootflash:
BB
Leo Laohoo
@suarej wrote:
Backup current IOS copy bootflash: tftp:
This is irrelevant.  If you want a "backup" of the old IOS-XE file, go and download the file(s) from the Cisco website.
@suarej wrote:
Verify dir bootflash:
  dir slavebootflash:
This stage does not provide any benefit.
Just wanted to make sure that the file is there
Recognize Your Peers
