12-31-2019 08:34 AM
Can anyone suggest the correct upgrade path for a 4500X VSS going from 3.6.7 to 3.11.xe? Can't seem to find any documentation on it. Is it safe to assume I can go straight from 3.6.7 to 3.11.xe?
Solved! Go to Solution.
05-09-2021 11:48 AM - edited 05-09-2021 11:48 AM
thx for the answer. but how does the switch skip the first boot command after upgrading the rommon? like I'm curious about the logic?
05-09-2021 05:20 PM
In every appliance, the bootup process will determine if the ROMMON will need to be updated or not. If not, then it skips the process.
Note that this step takes time. If the switch ROMMON is already updated, take the ROMMON boot statement off so the appliance will boot a lot faster.
01-15-2023 08:17 PM
Hi Leo
Do the licenses on the switch change based on these steps?
Thanks, John
01-15-2023 09:03 PM
No, the license are not touched.
02-11-2024 04:59 AM
Hi, sorry to hijack an old thread, but will this process work on 03.06.05.E.152-2.E5?
I am looking to upgrade to the latest version and have never done this before on 4500X so want to get it right.
02-11-2024 02:20 PM
Yes, the thread is valid for Catalyst 4500X, including Sup7.
The latest firmware that can support 4500X and Sup7 (unofficially) is 3.11.9, however, there is an SSH I want to warn everyone about: CSCwi02895
The unofficial workaround is to configure EEM.
02-15-2024 08:55 AM
Thanks, so to be clear I can go from my old version of 03.06.05, straight to 3.11.9 (or something like 3.11.6E to avoid the SSH bug)?
02-15-2024 03:49 PM
Direct upgrade to 3.11.9 is supported.
02-16-2024 05:12 AM
Great thanks, can I also go from ROM: 15.0(1r)SG12 to 15.0(1r)SG15?
02-16-2024 04:30 PM
Direct ROMMON upgrade is supported and highly recommended.
