11-09-2016 01:03 AM - edited 03-08-2019 08:06 AM
A working 4500X VSS pair with 3.6(4) SW and OSPF adjacencies in one SVI is reloaded (shelf-reload). The system comes up but the OSPF adj won't come up no matter how long you wait.
If you then only do another shelf-reload of the 4500X VSS, everything works.
Unfortunately I don't have any debugging output or show commands during the problem from neither side.
Side A: 4500X VSS
Side B: Nexus 7000 (dual sups)
OSPF Area x (NSSA)
OSPF MD5 Auth
OSPF Hello Interval 1s
The OSPF Peer (N7K) is is pingable during the problem.
If anyone knows this and a bug ID, this would be cool. Otherwise we'll have to wait for the next occurance and debug (optional with TAC).
!4500X
interface Vlan3201
description TS-OSPFDIR-1
ip address x.x.x.x 255.255.255.248
no ip redirects
ip pim query-interval 1
ip pim sparse-mode
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 7 xxxx
ip ospf hello-interval 1
ip ospf priority 5
ip ospf 1 area 201
no ipv6 redirects
router ospf 1
router-id x.x.x.x
ispf
auto-cost reference-bandwidth 100000
nsf ietf
area 201 nssa
timers throttle spf 10 100 5000
timers throttle lsa 10 100 5000
timers lsa arrival 80000
timers pacing lsa-group 15
passive-interface default
no passive-interface Vlan3201
network 0.0.0.0 255.255.255.255 area 201
11-09-2016 07:20 AM
There seem to be a hello interval mismatch, as I see this only on one side.
For testing, you may want to eliminate this command and maybe the timers commands before rebooting and see if there is a change.
11-09-2016 08:46 AM
Hello
Is this one of many ospf adjecencys by the only one that doesn't re establish ?
Regards the shelf reload do you have DAD enabled for gel link failure?
Res
Paul
