4506 8-E Sup
Nicholas Clay
Just recently purchased a sup 8E to replace a 6LE in a 4506. The 8 has been installed and operating, the issue I am having is out of the blue the switch starts vlan by vlan dropping connectivity to were I am left with a switch that is doing nothing. When I console in to the switch all VLANS and interfaces are showing up. But no data is passing through the switch, and no errors are being logged, while the routing table stays populated. Really kind of lost on this one.
When I switch back to the 6LE sup everything runs stable and normal.
Reza Sharifi
Most likely, that is an issue with the IOS you have installed.  Try upgrading or downgrading one version and test again.
Reza Sharifi
The Sup came with a differed release on it.
