09-01-2010 05:36 PM - edited 03-06-2019 12:46 PM
I am working with a customer who is migrating from 4503 and 4506 classic to 4503-E chassis.
I have not had any issues migrating from the 4503 classic chassis to the 4503-E chassis
I experienced an issue when attempting to migrate from the 4506 chassis to the 4503-E chassis. The Supervisor Engine IV would not power up when moved to the 4503-E. The LED does not light up and there is no output to the console. I have tried two different 4503-E chassis.
It is the same Supervisor model, IOS version and power supply. The Supervisor and lines cards work fine when I moved them back to the 4506 chassis.
Running release 12.2(37)SG.
Any ideas????
09-01-2010 05:42 PM
Just guessing here ... Wrong slot?
09-01-2010 05:43 PM
Should be slot 1
09-02-2010 03:33 PM
I hope you won't get upset with this answer ...
4500E will, according to the two conflicting data sheet, will only take Supervisor 6E/6LE.
Here are the two CONFLICTING data sheet:
Cisco Catalyst 4500 Series Line Cards
Introduction: Cisco Catalyst 4503-E Switch
http://www.cisco.com/en/US/products/ps9295/index.html
Please don't forget to rate useful posts. Thanks.
