02-12-2015 09:10 AM - edited 03-07-2019 10:37 PM
Hi Guys,
I've got this issue later wherein my Catalyst 4506 SW (with the modules and power supplies below) had ports in module 2 that do not provide power to the connected phones. There are ports in module 2 that provide power to phones, I think only 26 ports are not working at the moment. Tried to adjust the power inline consumption/static commands but still those ports failed to supply power to the connected phones.
Mod 1 - WS-X4013+
Mod 2 to 6 - WS-X4248-RJ45V
PS1 PWR-C45-4200ACV AC 4200W good
PS2 PWR-C45-4200ACV AC 4200W good
SW3#sh power inline f2/37
Available:3675(w) Used:1217(w) Remaining:2458(w)
Interface Admin Oper Power(Watts) Device Class
From PS To Device
Fa2/37 auto off 0.0 0.0 n/a n/a
Interface AdminPowerMax AdminConsumption
(Watts) (Watts)
Fa2/37 15.4 7.0
I also see these messages on the switch logs.
Feb 11 10:02:40.012 UTC: %C4K_CHASSIS-5-POEHEALTHCHECKFAILED: Poe Health Check failed on slot 2 (count = 96)
Feb 12 10:02:37.989 UTC: %C4K_CHASSIS-5-POEHEALTHCHECKFAILED: Poe Health Check failed on slot 2 (count = 100)
Does the 4506 has a limitation on the maximum number of PoE ports that it can power up given my modules and power supply capacity mentioned above?
02-12-2015 07:48 PM
What is the output of sh power?
03-01-2015 11:35 AM
Thanks for the replies Guys, this has been resolved after reseating the module.
02-15-2015 05:44 AM
Explanation: %C4K_CHASSIS-5-POEHEALTHCHECKFAILED: Poe Health Check failed on slot [dec] (count = [dec]) PoE health check has failed on a module. The PoE service provided by the module may be unavailable. Recommended Action: If the message shows up rarely and coincides with external events such as input power supplies being changed, this message can be safely ignored. If the message shows up continuously, please contact your Cisco representative for a replacement of the module.
You can reseat the module, check whether it can recover, if not , I think you need try to replace the module.
Jack
