12-19-2012 12:01 AM - edited 03-07-2019 10:41 AM
on this switch
WS-C4507R-E
with this modules:
1 WS-X4648-RJ45V+E
2 WS-X4648-RJ45V+E
3 WS-X45-SUP6-E
4 WS-X45-SUP6-E
5 WS-X4548-GB-RJ45
7 WS-X4648-RJ45V-E
i ve a problem: two Cisco AIR-LAP Accesspoints have been connected to modul2 with poe.
from one day to another these accesspoints are not connected.
Port-config, not working port:
interface GigabitEthernet2/47
description frei
switchport access vlan 57
switchport mode access
no logging event link-status
no logging event trunk-status
shutdown
duplex full
rmon native
rmon collection stats 96 owner config
spanning-tree portfast
spanning-tree bpduguard enable
end
when i connect these accesspoints to modul1 they are working. connection to other ports on modul2 doesnt work.
Port-config, working port:
interface GigabitEthernet1/5
description direkt AP-19
duplex full
no snmp trap link-status
rmon native
rmon collection stats 6 owner config
end
there are only two " AIR-LAP1242AG-E-K9" connected.
power output:
bciscoQR2#sh power
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-4200ACV AC 4200W good good good
PS1-1 220V good
PS1-2 220V good
PS2 PWR-C45-4200ACV AC 4200W good good good
PS2-1 220V good
PS2-2 220V good
Power supplies needed by system : 1
Power supplies currently available : 2
Power Summary Maximum
(in Watts) Used Available
System Power (12V) 916 1360
Inline Power (-50V) 32 3244
Backplane Power (3.3V) 40 40
Total 988 (not to exceed Total Maximum Available = 4200)
is it possible to disable poe on one modul or do we have an hardware error?
kind regards
andreas
12-19-2012 12:04 AM
Can you post the output to the command "sh power inline" when you connect the WAP to the 2nd line card.
How do you connect the WAP to the 1st and 2nd line card? Are you using the same patch cable?
12-19-2012 12:13 AM
Hi leolaohoo,
thanks for your fast reply. here is the output:
bciscoQR2(config-if)#do sh power inlin g 2/47
Available:3244(w) Used:0(w) Remaining:3244(w)
Interface Admin Oper Power(Watts) Device Class
From PS To Device
Gi2/47 auto off 0.0 0.0 n/a n/a
Interface AdminPowerMax AdminConsumption
(Watts) (Watts)
and yes, i am using the same patchcords.
12-19-2012 12:18 AM
Hmmmm ... Possible Layer 1 issue. And you're using a 4500 ... not making it easy.
Can you connect the WAP directly to the switch port (bypassing the horizontal cabling)?
12-19-2012 12:23 AM
the wap is located near to the switch and is directly connected.
12-19-2012 12:28 AM
I don't want this SPECIFIC command. Please post an un-adulterated output to the command "sh power inline".
12-19-2012 02:31 AM
sh power inline
From PS To Device
Gi1/1 off off 0.0 0.0 n/a n/a
Gi1/2 off off 0.0 0.0 n/a n/a
Gi1/3 off off 0.0 0.0 n/a n/a
Gi1/4 off off 0.0 0.0 n/a n/a
Gi1/5 off off 0.0 0.0 n/a n/a
Gi1/6 off off 0.0 0.0 n/a n/a
Gi1/7 off off 0.0 0.0 n/a n/a
Gi1/8 off off 0.0 0.0 n/a n/a
Gi1/9 off off 0.0 0.0 n/a n/a
Gi1/10 off off 0.0 0.0 n/a n/a
Gi1/11 off off 0.0 0.0 n/a n/a
Gi1/12 off off 0.0 0.0 n/a n/a
Gi1/13 off off 0.0 0.0 n/a n/a
Gi1/14 auto off 0.0 0.0 n/a n/a
Gi1/15 auto off 0.0 0.0 n/a n/a
Gi1/16 off off 0.0 0.0 n/a n/a
Gi1/17 off off 0.0 0.0 n/a n/a
Gi1/18 off off 0.0 0.0 n/a n/a
Gi1/19 off off 0.0 0.0 n/a n/a
Gi1/20 off off 0.0 0.0 n/a n/a
Gi1/21 off off 0.0 0.0 n/a n/a
Gi1/22 off off 0.0 0.0 n/a n/a
Gi1/23 off off 0.0 0.0 n/a n/a
Gi1/24 off off 0.0 0.0 n/a n/a
Gi1/25 off off 0.0 0.0 n/a n/a
Gi1/26 off off 0.0 0.0 n/a n/a
Gi1/27 off off 0.0 0.0 n/a n/a
Gi1/28 off off 0.0 0.0 n/a n/a
Gi1/29 off off 0.0 0.0 n/a n/a
Gi1/30 off off 0.0 0.0 n/a n/a
Gi1/31 off off 0.0 0.0 n/a n/a
Gi1/32 off off 0.0 0.0 n/a n/a
Gi1/33 off off 0.0 0.0 n/a n/a
Gi1/34 off off 0.0 0.0 n/a n/a
Gi1/35 off off 0.0 0.0 n/a n/a
Gi1/36 off off 0.0 0.0 n/a n/a
Gi1/37 off off 0.0 0.0 n/a n/a
Gi1/38 off off 0.0 0.0 n/a n/a
Gi1/39 off off 0.0 0.0 n/a n/a
Gi1/40 off off 0.0 0.0 n/a n/a
Gi1/41 off off 0.0 0.0 n/a n/a
Gi1/42 off off 0.0 0.0 n/a n/a
Gi1/43 off off 0.0 0.0 n/a n/a
Gi1/44 off off 0.0 0.0 n/a n/a
Gi1/45 off off 0.0 0.0 n/a n/a
Gi1/46 off off 0.0 0.0 n/a n/a
Gi1/47 off off 0.0 0.0 n/a n/a
Gi1/48 off off 0.0 0.0 n/a n/a
Gi2/1 auto off 0.0 0.0 n/a n/a
Gi2/2 auto off 0.0 0.0 n/a n/a
Gi2/3 auto off 0.0 0.0 n/a n/a
Gi2/4 auto off 0.0 0.0 n/a n/a
Gi2/5 auto off 0.0 0.0 n/a n/a
Gi2/6 auto off 0.0 0.0 n/a n/a
Gi2/7 auto off 0.0 0.0 n/a n/a
Gi2/8 off off 0.0 0.0 n/a n/a
Gi2/9 off off 0.0 0.0 n/a n/a
Gi2/10 off off 0.0 0.0 n/a n/a
Gi2/11 off off 0.0 0.0 n/a n/a
Gi2/12 off off 0.0 0.0 n/a n/a
Gi2/13 off off 0.0 0.0 n/a n/a
Gi2/14 off off 0.0 0.0 n/a n/a
Gi2/15 off off 0.0 0.0 n/a n/a
Gi2/16 off off 0.0 0.0 n/a n/a
--More-- Interface Admin Oper Power(Watts) Device Class
From PS To Device
Gi2/17 off off 0.0 0.0 n/a n/a
Gi2/18 off off 0.0 0.0 n/a n/a
Gi2/19 off off 0.0 0.0 n/a n/a
Gi2/20 off off 0.0 0.0 n/a n/a
Gi2/21 off off 0.0 0.0 n/a n/a
Gi2/22 off off 0.0 0.0 n/a n/a
Gi2/23 off off 0.0 0.0 n/a n/a
Gi2/24 off off 0.0 0.0 n/a n/a
Gi2/25 off off 0.0 0.0 n/a n/a
Gi2/26 off off 0.0 0.0 n/a n/a
Gi2/27 off off 0.0 0.0 n/a n/a
Gi2/28 off off 0.0 0.0 n/a n/a
Gi2/29 off off 0.0 0.0 n/a n/a
Gi2/30 off off 0.0 0.0 n/a n/a
Gi2/31 off off 0.0 0.0 n/a n/a
Gi2/32 off off 0.0 0.0 n/a n/a
Gi2/33 off off 0.0 0.0 n/a n/a
Gi2/34 off off 0.0 0.0 n/a n/a
Gi2/35 auto off 0.0 0.0 n/a n/a
Gi2/36 auto off 0.0 0.0 n/a n/a
Gi2/37 off off 0.0 0.0 n/a n/a
Gi2/38 off off 0.0 0.0 n/a n/a
Gi2/39 off off 0.0 0.0 n/a n/a
Gi2/40 off off 0.0 0.0 n/a n/a
Gi2/41 off off 0.0 0.0 n/a n/a
Gi2/42 off off 0.0 0.0 n/a n/a
Gi2/43 off off 0.0 0.0 n/a n/a
Gi2/44 off off 0.0 0.0 n/a n/a
Gi2/45 off off 0.0 0.0 n/a n/a
Gi2/46 off off 0.0 0.0 n/a n/a
Gi2/48 auto off 0.0 0.0 n/a n/a
Gi7/1 auto off 0.0 0.0 n/a n/a
Gi7/2 auto off 0.0 0.0 n/a n/a
Gi7/3 auto off 0.0 0.0 n/a n/a
Gi7/4 auto off 0.0 0.0 n/a n/a
Gi7/5 auto off 0.0 0.0 n/a n/a
Gi7/6 auto off 0.0 0.0 n/a n/a
Gi7/7 auto off 0.0 0.0 n/a n/a
Gi7/8 auto off 0.0 0.0 n/a n/a
Gi7/9 auto off 0.0 0.0 n/a n/a
Gi7/10 auto off 0.0 0.0 n/a n/a
Gi7/11 auto off 0.0 0.0 n/a n/a
Gi7/12 auto off 0.0 0.0 n/a n/a
Gi7/13 auto off 0.0 0.0 n/a n/a
Gi7/14 auto off 0.0 0.0 n/a n/a
Gi7/15 auto off 0.0 0.0 n/a n/a
Gi7/16 auto off 0.0 0.0 n/a n/a
Gi7/17 auto off 0.0 0.0 n/a n/a
Gi7/18 auto off 0.0 0.0 n/a n/a
Gi7/19 auto off 0.0 0.0 n/a n/a
Gi7/20 auto off 0.0 0.0 n/a n/a
Gi7/21 auto off 0.0 0.0 n/a n/a
Gi7/22 auto off 0.0 0.0 n/a n/a
Gi7/23 auto off 0.0 0.0 n/a n/a
Gi7/24 auto off 0.0 0.0 n/a n/a
Gi7/25 auto off 0.0 0.0 n/a n/a
Gi7/26 auto off 0.0 0.0 n/a n/a
Gi7/27 auto off 0.0 0.0 n/a n/a
Gi7/28 auto off 0.0 0.0 n/a n/a
Gi7/29 auto off 0.0 0.0 n/a n/a
Gi7/30 auto off 0.0 0.0 n/a n/a
Gi7/31 auto off 0.0 0.0 n/a n/a
Gi7/32 auto off 0.0 0.0 n/a n/a
Gi7/33 auto off 0.0 0.0 n/a n/a
From PS To Device
Gi7/34 auto off 0.0 0.0 n/a n/a
Gi7/35 auto off 0.0 0.0 n/a n/a
Gi7/36 auto off 0.0 0.0 n/a n/a
Gi7/37 auto off 0.0 0.0 n/a n/a
Gi7/38 auto off 0.0 0.0 n/a n/a
Gi7/39 auto off 0.0 0.0 n/a n/a
Gi7/40 auto off 0.0 0.0 n/a n/a
Gi7/41 auto off 0.0 0.0 n/a n/a
Gi7/42 auto off 0.0 0.0 n/a n/a
Gi7/43 auto off 0.0 0.0 n/a n/a
Gi7/44 auto off 0.0 0.0 n/a n/a
Gi7/45 auto off 0.0 0.0 n/a n/a
Gi7/46 auto off 0.0 0.0 n/a n/a
Gi7/47 auto off 0.0 0.0 n/a n/a
Gi7/48 auto off 0.0 0.0 n/a n/a
Totals: 0 on 0.0 0.0
12-19-2012 02:44 AM
Thanks. The output helps eliminate a suspect. Next, TDR.
Do this:
1. Command: test cable tdr interface G2/47;
2. Wait for 61 seconds (Yes, for a 4500 line card it takes THAT long!)
3. Command: sh cable tdr interface G2/47; and
4. Post the complete output (don't leave anything out).
12-19-2012 03:29 AM
Test is not possible, Logging-Event:
%C4K_IOSDIAGMAN-4-TESTNOTSUPPORTEDONMODULE: Online cable diag tdr test is not supported on module 2
%C4K_IOSDIAGMAN-4-TESTNOTSUPPORTEDONMODULE: Online cable diag tdr test is not supported on module 1
But the cable is still working on module1
12-19-2012 01:56 PM
If there's no other client connected to module 2, can I ask if you can re-seat the module and post the entire bootup process of the module?
12-20-2012 07:18 AM
Your Gi2/47 port configuration shows "shutdown". Can you please do "no shut".
Best regards,
Antonin
