08-10-2014 11:46 PM - edited 03-07-2019 08:20 PM
MY core switch 4507R+E
(cat4500es8-UNIVERSAL-M), Version 03.03.00.XO RELEASE SOFTWARE (fc2)
'WS-X45-SUP8-E'
when I connected distribution switch 10G cable then LED collor goes green to orange and after 3 to 4 hours I cant ping to any interface without managemenet ip
08-11-2014 01:33 AM
Possibly means the interface has gone into error-disable.
Can you kindly post the output to the command "sh interface status err"?
08-11-2014 03:30 AM
Thanks for your response...
CSw1#sh interfaces status err
showing nothing...
ervery after 4 hours core switch not responding . when I restart it then it goes normal and after 4 hours again it not responding.
and sup status led which is green normaly when I connect DS SW then it goes to amber color..
waiting for your reply..
08-15-2014 03:53 AM
waiting for response...........
08-15-2014 08:16 PM
Did you look at the document I referenced and can you answer the question I asked?
08-16-2014 09:13 PM
Dear Marvin,
I have solve this problem.I have updated IOS cat4500es8-universal.SPA.03.03.01.XO.151-1.XO1.bin and set MTU on both side and now working fine .
08-03-2015 02:14 PM
This discussion has been reposted from Additional Communities to the LAN, Switching and Routing community.
08-11-2014 06:17 AM
Which LED goes orange?
The LED status codes are in this document.
Your syslog entries (or a PC connected to a console port) will give you more details on what is happening on the device.
