08-23-2009 04:20 AM - edited 03-06-2019 07:22 AM
Hi, helping a friend set up a network using 3750 as the core and 520 Express as remote switches ( 24 LC versions )
Reading cisco own documentation on the web it suggests that upto 32 Vlans can be configured on the 520's, see link :
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7238/product_data_sheet0900aecd8060aee4.html
On the Layer 2 details it specifies "Upto 32 VLANs".
But using CCA I am only about to configure 16 before I get the "maximum vlans" error message ?
My friend requires more than this and is hoping this is not the limit !!
Any advice appreciated.
08-23-2009 08:19 AM
The maximum number of VLANs allowed for UC500 is 15.
If you go on the command line and try to create a vlan, it should not work either.
The documentation is wrong, to fix it, we will need a TAC case.
Log in to Community
