10-08-2010 06:18 AM - edited 03-06-2019 01:24 PM
Hi Commnity,
We have two cisco 6500 swtiches. Switch A is a active state of HSRP and Switch B in stanby state, After 2 days we are going have go-live test for Switches failove redudancy.
Please see the sample HSRP confiuration for both switches
SWTICH A
interface Vlan 100
description << RECEPTION>>
ip address 10.1.2.254 255.255.255.0
ip route-cache flow
standby delay minimum 20 reload 25
standby 3 ip 10.1.2.1
standby 3 priority 110
standby 3 preempt delay minimum 380
SWITCH B
interface Vlan3
ip address 10.1.2.253 255.255.255.0
ip route-cache flow
standby 3 priority 95
SWITCH A# sh stanby brief
Interface Grp Prio P State Active addr Standby addr Group addr
Vl3 3 110 P Active local 10.1.2.253 10.1.2.1
SWITCH B #
Vl3 3 95 P Standby local local 10.1.2.1
If there is any misconfiguration, your sugesstion will be highly appreciated.
10-13-2010 01:47 PM
I think it's also recommended that trunks be set to desirable on one switch, the other to auto
10-14-2010 08:08 AM
In your very first post I don't understand this config , you have the same address space in 2 different vlans . They should be in the same L3 vlan on both sides. You have one side as vlan 100 and the other as vlan 3 . I would verify you have not done this on other vlans too ...
SWTICH A
interface Vlan 100
ip route-cache flow
SWITCH B
interface Vlan3
ip route-cache flow
10-14-2010 01:24 PM
Hi glen,
Actually it was wrongly posted, currently we are working here vlan 2 and vlan 19.
10-15-2010 01:33 PM
I haven't recieved any reply so far from the experts.
Anyway I got it working.
Thanks to Jon and other people who showed there effort towards this issue and I really appreciate that.
10-15-2010 01:41 PM
What did you do to finally get it working?
---Mike
10-15-2010 01:43 PM
Like Mike, i would be very interested to hear what you did that made it work.
Jon
10-15-2010 01:50 PM
Hi Mike and Jon,
Here my scope was to test the two 6500 failover.
Finally I shutdown my core 1 and core 2 became active within 15 seconds. Everthing was working fine. No vlans got any issue.
I was really amazed.
Samir
10-18-2010 12:57 AM
Hi Jon,
I hope you are doing well.
Please can you check the below link for my post. and can you help me in that issue
https://supportforums.cisco.com/thread/2047503?tstart=0
I would be grateful.
Thank
12-28-2011 12:40 AM
Dear Samir ,
Why don't you create ether channel between switches...instead of trunk link .
SWTICH A config :
interface Vlan 100
ip route-cache flow
standby 3 preempt
interface Port-channel5
description ****Ether channel between 6500 *****
switchport
switchport mode trunk
Interface gig 2/23
channel-group 5 mode on
SWITCH B
interface Vlan3
ip route-cache flow
standby 3 preempt
switchport
Interface gig 2/23
Note : You can place one more port on ether channel so that you would have redundancy for ether channel link.
HSRP messages will be listened through ether channel and whenever you shut down vlan on switch A , vlan will be active on switch B immediatly.
With Rgds,
Satish
