310
Highlighted
Beginner
6500 NAT between Vlans max entries
I'm having a problem doing NAT translations between Vlans. I have a nat inside vlan with a private segment and a nat outside vlan with a public ip address. The problem I'm having is that at times the CPU of the switch peaks to 100%. I think it's a limitation of the 6500 when it gets to the max nat entries. The process IP NAT ager is the one I have with the most utilization with 80-90%. Here is a show ip nat statistics. The question is what is the max nat entries for the 6500 so I can configure it as the max-entries?
Router#sh ip nat statistics
Total active translations: 10763 (0 static, 10763 dynamic; 10763 extended)
Outside interfaces:
Vlan504
Inside interfaces:
Vlan505, Vlan506, Vlan507, Vlan508, Vlan509
Hits: 55987246 Misses: 24073282
Expired translations: 23469806
Dynamic mappings:
-- Inside Source
[Id: 2] route-map Priv-IPs-NAT interface Vlan504 refcount 10763
Router#
1 REPLY 1
Highlighted
Contributor
Re: 6500 NAT between Vlans max entries
PAT/NAT are Netflow derived features and as such are accelerated, but not entirely done in hardware its also depends on the software. So there is high cpu usage.
Content for Community-Ad
