6500 not booting neither from bootdisk or disk0: with illegal opcode error
krir
Level 4
Level 4
One of the 6500 was going in bootrom mode,  so I have formated the flash disk using the other Cisco 6500 switch and copied IOS file to the  boot disk. But the 6500 booting failed with the following error
rommon 1 > boot disk0:/s72033-adventerprisek9_wan-mz.122-33.SXI9.bin
Loading image, please wait ...
Initializing ATA monitor library...
*** Illegal Opcode Exception ***
PC = 0x801060e4, Cause = 0x28, Status Reg = 0x30409003
monitor: command "boot" aborted due to exception
Awaiting your kind revert
R.Krishnan.
6 Replies 6
Leo Laohoo
This looks like the IOS is corrupt.
Check the bootdisk/bootflash for any crashfiles. Might also be a corrupted IOS. Best way to confirm is to take a flash from another working 6500 after testing SXI9 to be working over there and use the same disk in this device. Not the easiest of methods
-Karthic
Leo Laohoo
Check the MD5 hash with YOUR file against the Cisco website.
Use the command "verify /md disk0:IOS.bin".  At the end of the process is long line of alpha-numeric numbers.  Compare that value against the Cisco website.
If they don't match you may need to download the IOS from the website once again.
Good point Leo.
Thanks Karthic.
Leo Laohoo
Would be very nice if the OP can give us an update to this as some people may find this thread useful.
