6500 Switch Question
skhirbash
I am reviewing a config file of a 6500-SW and it shows that there are 5 VLANS configued. When I did a show cdp neighbor details, it only showed the default vlan (VLAN1) and no physical links to any other devices. This switch is offsite and I just got the assignment to analyze the network toplogy and document it. The question is, what command(s) can I used to see what the phyiscal links on this switch is/are?
Your help is very much appreciated,
sK
18 Replies 18
6500-SW#sho cdp neighbors detail
Device ID: TBA05280230(dha-sw1)
Entry address(es):
IP address: 192.168.1.2
Platform: WS-C6509, Capabilities: Trans-Bridge Switch IGMP
Interface: Vlan1, Port ID (outgoing port): 15/1
Holdtime : 132 sec
Version :
WS-C6509 Software, Version McpSW: 7.6(11) NmpSW: 7.6(11)
Copyright (c) 1995-2005 by Cisco Systems
advertisement version: 2
VTP Management Domain: 'YYY'
Try this. From the enable prompt
telnet 192.168.1.2 - hopefully you know the passwords to log onto the supervisor.
If you can log on run the following command
"sh port"
whichh should show you the physical interfaces.
You can also run a "sh module" and you should see a full module list.
Jon
Thanks Jon. I think that will do the trick. I don't have the supervisor's pwd yet. Once I do, I will use the commands you mentiond go accomplish what I need.
Thanks again,
sK
No problem. Let us know if you get any more problems.
Apologies for taking so long to get to the point ! - it really is a while since i have used hybrid on a 6500 :)
Jon
