6509 Chassis
We have a 6509 Chassis (WS-C6509) with Sup720
Questions below
Is this hardware (Chassis) supported or is end of life ?
I have used the link below but they mention 6509 and not WS-C6509 just wanted to double check if the meant the same ?
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_models_comparison.html
We have used this hardware for the last 7 years are they any know issues with the hardware or is it good practice to the move to the latest Chassis to avoid suprises ?
Disclaimer
The       Author of this posting offers the information contained within  this      posting without consideration and with the reader's  understanding   that    there's no implied or expressed suitability or  fitness for any    purpose.   Information provided is for informational  purposes only  and   should not   be construed as rendering professional  advice of any  kind.   Usage of  this  posting's information is solely  at reader's own  risk.
Liability Disclaimer
In       no event shall Author be liable for any damages whatsoever     (including,   without limitation, damages for loss of use, data or     profit) arising  out  of the use or inability to use the posting's     information even if  Author  has been advised of the possibility of    such  damage.
Posting
The -E chassis comes with standard with the high speed fans to allow sup720s to be installed (earlier chassis can be upgraded).
The -E chassis also provides 80 Gbps per slot for the sup2t.
5 Replies 5
Reza Sharifi
They are the same thing..
WS-C6509 is the part number for the chassis.
Sup 720 is a few years old.  The newest Sup module is Sup-2T
Thanks for your swift response
Are they any know problem with the physical Chasis WS-C6509 with the black plain etc ?
Any Advantages for us to migrate to 6509-E Chassis ?
It depends what you are trying to do.  What features you want to add and use.
Have a look at this link.  It does a good comparisom of different sup modules and what they support:
Disclaimer
Posting
Leo Laohoo
EOS for Selective Cisco Catalyst 6503,Catalyst 6506 and Catalyst 6509 Chassis
