10-02-2017 05:59 AM - edited 03-08-2019 12:14 PM
I am running a VSS consisting of two 6509-E with Sup720 MSFC3. The IOS is a 15.1(2)SY2. I tried to upgrade to 15.1(2)SY5. According to the ISSU compatibility matrix this should work. I did a "issu loadversion", and as soon as the second supervisor came up with the new software the active sup logs:
%ISSU-SW2_SPSTBY-3-NOT_FIND_UNDER_SESSION: Can not find control block under session group for msg type(117) under receive transform session(652).
%ISSU_ERROR-SW2_SPSTBY-3-TRANSFORM_FAILED: ISSU VS Power Client(6056): receive transformation failed (ISSU_RC_MSG_TYPE_NOT_FOUND)
%ISSU_ERROR-SW2_SPSTBY-3-MSG_MTU: ISSU VS Power Client(6056): Client failed to get mtu for message 118 (ISSU_RC_NEGO_RESULT_NOT_FOUND)
%ISSU_ERROR-SW2_SPSTBY-3-TRANSFORM_FAILED: ISSU VS Power Client(6056): transmit transformation failed (ISSU_RC_MSG_TYPE_NOT_FOUND)
%ISSU-SW1_SP-3-INCOMPATIBLE_PEER_UID: Setting image (s72033_sp-IPSERVICESK9-M), version (15.1(2)SY5) on peer uid (517) as incompatible
%ISSU_PROCESS-SW1_SP-4-ABORT_ISSU: Service Incompatibility - Aborting the ISSU process
%ISSU_PROCESS-SW1_SP-3-ABORT: Abortversion still in progress, please wait ...
%ISSU_PROCESS-SW1_SP-3-ABORT: Resetting Standby shortly
After that the secondary sup reboots the old ios and the issu is cancelled.
Any ideas?
10-02-2017 06:39 AM - edited 10-02-2017 06:39 AM
Did you verify that it is actually going to work?
See this document.
10-02-2017 08:54 AM
This was the output of "show switch virtual redundancy" before the upgrade. It was in SSO mode, hot standby.
#show switch virtual red
My Switch Id = 1
Peer Switch Id = 2
Last switchover reason = user forced
Configured Redundancy Mode = sso
Operating Redundancy Mode = sso
Switch 1 Slot 5 Processor Information :
Current Software state = ACTIVE
Uptime in current state = 2 years, 42 weeks, 5 days, 22 hours, 56 minutes
Image Version = Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 15.1(2)SY2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 26-Feb-14 16:36 by prod_rel_team
BOOT = sup-bootdisk:s72033-ipservicesk9-mz.151-2.SY2.bin,1;bootdisk:s72033-ipservicesk9-mz.151-2.SY2.bin,12;
Configuration register = 0x2102
Fabric State = ACTIVE
Control Plane State = ACTIVE
Switch 2 Slot 5 Processor Information :
Current Software state = STANDBY HOT (switchover target)
Uptime in current state = 2 years, 42 weeks, 5 days, 22 hours, 34 minutes
Control Plane State = STANDBY
10-04-2017 08:05 AM
I checked once more according to the document you sent and found no problems in the config:
wiss#show redundancy
Redundant System Information :
Available system uptime = 4 years, 1 week, 3 days, 6 hours, 27 minutes
Switchovers system experienced = 8
Standby failures = 0
Hardware Mode = Duplex
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 1/5
Uptime in current state = 33 minutes
BOOT = bootdisk:s72033-ipservicesk9-mz.151-2.SY2.bin,12;bootdisk:s72033-ipservicesk9-mz.151-2.SY4.bin,12;
Peer Processor Information :
Standby Location = slot 2/5
Uptime in current state = 27 minutes
wiss#show issu state detail
The system is configured to be upgraded in in-tandem mode.
Platform has forced upgrade to in-tandem mode.
2 supervisor nodes are found to be online.
Summary: the system will be upgraded in in-tandem mode.
Slot = 1/5
RP State = Active
ISSU State = Init
Boot Variable = bootdisk:s72033-ipservicesk9-mz.151-2.SY2.bin,12;bootdisk:s72033-ipservicesk9-mz.151-2.SY4.bin,12;
Operating Mode = sso
ISSU Sub-State = No Upgrade Operation in Progress
Starting Image = N/A
Target Image = N/A
Current Version = bootdisk:s72033-ipservicesk9-mz.151-2.SY2.bin
Slot = 2/5
RP State = Standby
ISSU State = Init
Target Image = N/A
I attached the logs from both supervisors.
