6509 manual reload
m.arancibia
After manual reload appears this message:
*Jun 28 08:05:09.675: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Jun 28 08:05:08.335: CM file (ivfs:/s72033_sp-advipservicesk9-m_matrix.cm) is not readable, using internal matrix table
*Jun 28 08:05:08.799: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
*Jun 28 08:05:08.839: %C6K_PLATFORM-4-DETECTED_NON_C7600_CHASSIS: Software has detected an attempt to run a c7600 image on an incompatible chassis WS-C6509 (36866)
*Jun 28 08:05:09.671: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
And the modules 1 and 8 turn down.
Can someone say me what is the possible cause?
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD0805022X
  3    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      JAF1212BRPG
  4    8  8 port 1000mb ethernet                 WS-X6408-GBIC      SAD041500KU
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL     SAD0951035V
  6    2  Supervisor Engine 720 (Hot)            WS-SUP720-3BXL     SAD1208029X
  7    8  8 port 1000mb GBIC Enhanced QoS        WS-X6408A-GBIC     SAL0506310M
  8   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAD091503B5
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  000e.83ea.c0d4 to 000e.83ea.c103   1.4   12.2(14r)S5  12.2(33)SRD  Ok
  3  001f.6cad.8490 to 001f.6cad.8493   2.7   12.2(14r)S5  12.2(33)SRD  Ok
  4  00d0.d3a0.d89c to 00d0.d3a0.d8a3   2.4   5.1(1)CSX    8.7(0.22)FW2 Ok
  5  0011.5cab.80bc to 0011.5cab.80bf   4.3   8.1(3)       12.2(33)SRD  Ok
  6  0013.807b.9ed0 to 0013.807b.9ed3   5.6   8.5(2)       12.2(33)SRD  Ok
  7  0001.9724.0c14 to 0001.9724.0c1b   1.3   5.4(2)       8.7(0.22)FW2 Ok
  8  0012.0059.a4a4 to 0012.0059.a4bb   2.2   12.2(14r)S5  12.2(33)SRD  Ok
------------------ show version ------------------
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRD, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 24-Oct-08 02:34 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
R6500 uptime is 9 weeks, 6 days, 19 hours, 43 minutes
Uptime for this control processor is 9 weeks, 6 days, 19 hours, 38 minutes
System returned to ROM by  power cycle (SP by power on)
System restarted at 10:25:45 BSAS Wed Apr 14 2010
System image file is "disk0:s72033-advipservicesk9-mz.122-33.SRD.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509 (R7000) processor (revision 2.0) with 983008K/65536K bytes of memory.
Processor board ID SCA050702WY
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
27 Virtual Ethernet interfaces
92 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Jerry Ye
As the following message describe
You are using the C7600 software (SRx train) on a C6500 hardware. This is not a support solution, and you should use the C6500 software instead (SXx).
jerry
