06-30-2007
08:49 AM
- last edited on
03-25-2019
03:55 PM
by
ciscomoderator
I have 6509 non E chassis. Do I have any need for concern if I want to deploy VoIP? Can I deploy the CCM modules andthe IOS to support them in a non E chassis?
Solved! Go to Solution.
06-30-2007 09:48 AM
You can still run the sup720 with the latest IOS on the 6500 non-E chassis and this confgiuration AFAIK will take all the service module cards including yours - i'm assuming you are referring to the CMM module ?
If however you want to power IP phones from the 6500 then yes it may be a concern. Attached is a link to a 6500 Enhanced chassis doc
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_bulletin0900aecd8017a5e7.html
scroll down to table 2 which covers number of phones that can be powered on different chassis.
Jon
06-30-2007 09:48 AM
Jon
07-03-2007 08:26 AM
Thanks Jon,
You answered my question, and cleared my concerns. And yes, i was refering to the CMM mods.
