6509 QoS Help
tf2-conky
I've tried to apply QoS based on 'priority' to an SVI on a 6509, and since discovered this is not supported.
I've spent a long time reading the Cisco docs on 6500 QoS, but I'm somewhat confused as to what I need to do to enable QoS for the following senario.
- A customer would like to guarantee 40% of available bandwidth( both ingress & egress) across a fibre WAN link based on IP addressing.
- The SVI is in a VRF.  The Vlan is trunked out a shared GigE interface to a 'transmission switch'. (I can move this to a dedicated physical GigE interface if necessary)
Any help greatly appreciated.
habadr
Ethernet interface has hardware queues in 6500 swtiches and you can not do shaping but you can allocate a queue for such traffic. It depends on your linecard qudeueing mechanism however I suugest that you review QOS SRND ver 4.0 for more details
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND_40/QoSCampus_40.html#wp1101384
Hatim Badr
