Join Customer Connection to register!
8631
jclj
Beginner
6509 Redundant Sup720 - Slave boots into Rommon
Hi. I'm fairly new to networking and need to migrate an old core to a new core. I have a 6509-e Switch that I had an RMA on one of my 720 sup cards. After receiving the sup card I swapped my slave out with the new one, expecting it to boot into ios. It booted into Rommon. I tried to boot the image manually and it did the same thing. I also tried to boot from my flash and, again, booted into Rommon.
Questions:
1. What am i missing here?
2. If i confreg and change the boot to boot from image it tells me i need to reset or power cycle first. Will this reset the entire switch? As this is production I'd rather not.
I am at home now, but I can supply any logs/hardware model/configs tomorrow. I thought I would see if this is an easy fix.
Thanks for the help.
1 ACCEPTED SOLUTION
Reza Sharifi
Hall of Fame Expert
Thanks for the update.
Please close the post and mark it as solved, so others can benefit from it.
23 REPLIES 23
Leo Laohoo
VIP Community Legend
Console into the redundant supervisor card and reboot.  Post the entire bootup process.
Thanks, so if I console in and reset this won't effect the rest of the switch? I wouldn't think so, but like i said i'm fairly new to this. Thanks
Leo Laohoo
If the redundant Sup720 is still in ROMmon then resetting it won't affect the rest of the chassis.
Reza Sharifi
Hall of Fame Expert
You also need to load the same exact IOS in the new sup to work in SSO mode:
follow this link to replace your sup:
https://supportforums.cisco.com/docs/DOC-21495
jclj
Beginner
I tried this already. The problem is even if I tell it to boot off my flash with the same ios as the active it starts to boot and then goes back to rommon. I will get the logs tomorrow and post.
I'm thinking i just need to change the confreg and reset, just wasn't sure if that would effect the rest of the switch.
Ivan Shirshin
Hi Chris,
Answering you 2nd question  - this will reset only the supervsor which is in ROMMON, the one which console you are using.
Reza and leolaohoo provided correct suggestions. One more reason for boot to fail could be that route processor confreg is incorrect. You can fix that this  way:
-  do manual boot with "boot" command and when you see "passed ownership to route processor", send a break sequence. This will put you into RP ROMMON.
- there execute
     confreg 0x2102
     sync
- then "reset" to test.
Console logs showing boot sequence would help to determine the cause of the issue.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
jclj
Beginner
ok guys, here is the reset from the slave sup card:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.10.26 10:47:35 =~=~=~=~=~=~=~=~=~=~=~=
rommon 2 > confreg 0x2102
You must reset or power cycle for new config to take effect
rommon 3 > syn         reset
System Bo otstrap, Version 8.5(4)
Copyright (c) 19 94-20 09 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot bootdisk:s72033-ipservices_wan-mz.122-33.SXH8b.bin"
Loading image, please wait ...
Initializing ATA monitor library...
Self extracting the image... [OK]
Self decompressing the image : ############################################################################################################################################################## [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, s72033_sp Software (s72033_sp-IPSERVICES_WAN-M), Version 12.2(33)SXH8b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 14-Sep-11 12:31 by prod_rel_team
Image text-base: 0x40101328, data-base: 0x41C70130
00:00:04: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:04: %PFREDUN-6-STANDBY: Initializing as STANDBY processor for this switch
00:00:05: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:04: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 13-Aug-10 11:12 by integ Build [100]
00:00:05: %OIR-6-CONSOLE: Changing console ownership to route processor
System Bo otstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
Technical Sup port: ht tp:/ /w w w.cisco.com/techsup port
Copyright (c) 20 09 by cisco Systems, Inc.
Cat6k-Sup720/RP platform with 524288 Kbytes of main memory
Download Start
Download Completed! Booting the image.
Self decompressing the image : ####################################################################################################################################################################################################################################### [OK]
           cisco Systems, Inc.
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(33)SXH8b, RELEASE SOFTWARE (fc1)
Compiled Wed 14-Sep-11 12:26 by prod_rel_team
Image text-base: 0x40101328, data-base: 0x42C2D750
rommon 1 >
jclj
Beginner
Does this help? It just dumps right back into rommon and I can't figure out why.
Hi Chris,
Please try to set confreg on RP as suggested above:
-  do manual boot with "boot" command and when you see "%OIR-6-CONSOLE: Changing console ownership to route processor", send a break sequence. This will put you into RP ROMMON.
- there execute
     confreg 0x2102
     sync
- then "reset" to test the boot again.
Kind Regards,
Ivan
Kind Regards,
Ivan
jclj
Beginner
How is this different than what I did? I changed the confreg to 0x2102 and reset.
Is rommon and RP rommon 2 different things?
Reza Sharifi
Hall of Fame Expert
There RP and SP.  What you originally changed was SP, now do the same as Ivan recommended for RP.
Also, if this does not work.  Try loading a new IOS into your new sup.  From what you posted, the existing IOS on the sup is very old and might be corrupted.
jclj
Beginner
Got ya, thanks. I did the above and got the same results. I also tried manually booting my iOS on my other SUP from flash with same results:
           cisco Systems, Inc.
Download Start
           cisco Systems, Inc.
rommon 1 >
Reza Sharifi
Hall of Fame Expert
When you are in rommon mode what is the output of
dir bootflash:
If you see the IOS, can you issue the boot command:
boot
example:
boot bootflash:s72033-ipservices_wan-mz.122-33.SXH8b.bin
jclj
Beginner
This is what I meant by a manual boot. I did do this again and here are the results. Not sure why this isn't booting to the image. It dumps it right back into rommon:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.10.30 10:09:02 =~=~=~=~=~=~=~=~=~=~=~=
rommon 1 > dir bootflsa      ahs      sh:
Directory of bootflash:
2      73785828  -rw-     s72033-ipservices_wan-mz.122-33.SXH8b.bin
3540    33554432  -rw-     sea_log.dat
rommon 2 > boot bootshla            flash:s72033-ipservices_wan-mz.122-33.SXH8b.bin
           cisco Systems, Inc.
Image text-base: 0x40101328, data-base: 0x41C68070
Download Start
           cisco Systems, Inc.
Image text-base: 0x40101328, data-base: 0x42C32B90
rommon 1 >
