6509 Supervisor election
h.kaemmerling
I have a 6509 that has dual SUP32's    Just want to make sure and give a reason(if there is one).
Slot 6 always becomes the active hot on a full reboot.  Meaning from no power to the whole switch to powered on.
Also.  What is the election process for Supervisors?
5 Replies 5
Reza Sharifi
If you have 2 sups, one in slot 5 and one in slot 6. when you reboot the switch and SSO in configured correctly.  Slot 5 should be the primary and slot 6 stand-by, unless the sup in slot 5 fails.
check with "sh redu" to make sure SSO is configured correctly
slot 5 should be active and slot 6 should be HOT
SSO is configured correctly and they are in HOT Active/Standby states.  And if we failover it works fine.  Just when the switch is booted up slot 6 becomes active.  One of the SUP's was RMA'd recently.
Show redundancy output. You can see slow 6 is active.
NYCWS-ACCESS-SW19B#sh red
Redundant System Information :
       Available system uptime = 3 hours, 6 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Duplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
              Maintenance Mode = Disabled
                Communications = Up
Current Processor Information :
               Active Location = slot 6
        Current Software state = ACTIVE
       Uptime in current state = 3 hours, 4 minutes
                 Image Version = Cisco IOS Software, s3223_rp Software (s3223_rp-ADVIPSERVICESK9_WAN-VM), Version 12.2(33)SXI3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 26-Oct-09 20:00 by prod_rel_team
                          BOOT = sup-bootdisk:s3223-advipservicesk9_wan-vz.122-33.SXI3.bin,1;
                       BOOTLDR =
        Configuration register = 0x2102
Peer Processor Information :
              Standby Location = slot 5
        Current Software state = STANDBY HOT
       Uptime in current state = 2 hours, 56 minutes
                       BOOTLDR =
It appears that slot 6 has been rebooted first (Uptime in current state = 3 hours, 4 minutes)
and than slot 5 came on line (Uptime in current state = 2 hours, 56 minutes)
Now, what happens if you reboot slot 6 only?
That's the thing.  We did a whole switch reload and and slot 6 became the active.  That means slot 6 came up before slot 5 right?
