06-17-2013 02:22 AM - edited 03-07-2019 01:55 PM
Hi to all
We have a 6513 with IOS 15.0(1)SY3 and we have a minor error on module 8 (active SUP) related to TestNonDisruptiveLoopback on port 5
What could be the problem? Is really a minor problem?
Here is the output:
sh module 8
Mod Ports Card Type Model Serial
No.
8 5 Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G
SAL16138MPH
Mod MAC addresses Hw Fw Sw
Status
8 588d.098a.fa0d to 588d.098a.fa14 1.3 12.2(50r)SYS 15.0(1)SY3 Ok
Mod Sub-Module Model Serial Hw
Status
8 Policy Feature Card 4 VS-F6K-PFC4 SAL16138AJ8 1.2 Ok
8 CPU Daughterboard VS-F6K-MSFC5 SAL161172LA 1.4 Ok
Mod Online Diag Status
8 Minor Error
sh diagnostic result module 8
Current bootup diagnostic level: minimal
Module 8: Supervisor Engine 2T 10GE w/ CTS (Active) SerialNo : SAL16138MPH
Overall Diagnostic Result for Module 8 : MINOR ERROR
Diagnostic level at card bootup: minimal
Test results: (. = Pass, F = Fail, U = Untested)
1) TestTransceiverIntegrity:
Port 1 2 3 4 5
. U U . .
2) TestLoopback:
Port 1 2 3 4 5
3) TestActiveToStandbyLoopback:
Port 1 2 3 4 5
U U U U U
4) TestL2CTSLoopback:
Port 1 2 3 4 5
5) TestL3CTSLoopback:
Port 1 2 3 4 5
6) TestScratchRegister -------------> .
7) TestNewIndexLearn ---------------> .
8) TestDontConditionalLearn --------> .
9) TestBpduTrap --------------------> .
10) TestMatchCapture ----------------> .
11) TestProtocolMatchChannel --------> .
12) TestMacNotification -------------> U
13) TestPortSecurity ----------------> .
14) TestIPv4FibShortcut -------------> .
15) TestL3Capture2 ------------------> .
16) TestIPv6FibShortcut -------------> .
17) TestMPLSFibShortcut -------------> .
18) TestNATFibShortcut --------------> .
19) TestAclPermit -------------------> .
20) TestAclDeny ---------------------> .
21) TestAclRedirect -----------------> .
22) TestRBAcl -----------------------> .
23) TestQos -------------------------> .
24) TestDQUP ------------------------> .
25) TestL3VlanMet -------------------> .
26) TestIngressSpan -----------------> .
27) TestEgressSpan ------------------> .
28) TestNetflowShortcut -------------> .
29) TestInbandEdit ------------------> .
30) TestFabricInternalSnake ---------> .
31) TestFabricExternalSnake ---------> U
32) TestFabricVlanLoopback ----------> .
33) TestTrafficStress ---------------> U
34) TestL3TcamMonitoring ------------> .
35) TestFibTcam ---------------------> U
36) TestAclQosTcam ------------------> U
37) TestEarlMemOnBootup -------------> .
38) TestAsicMemory ------------------> U
39) ScheduleSwitchover --------------> U
40) TestFirmwareDiagStatus ----------> .
41) TestAsicSync --------------------> .
42) TestUnusedPortLoopback:
Port 1 2 3 4 5
U . . U U
43) TestNonDisruptiveLoopback:
Port 1 2 3 4 5
. U U . F
44) TestFabricFlowControlStatus -----> U
45) TestPortTxMonitoring:
Port 1 2 3 4 5
U U U U U
46) TestOBFL ------------------------> .
47) TestCFRW:
Device 1
U
48) TestLtlFpoeMemoryConsistency ----> .
49) TestErrorCounterMonitor ---------> .
50) TestEARLInternalTables ----------> .
51) TestNVRAMBatteryMonitor ---------> .
52) TestMediaLoopback:
Port 1 2 3 4 5
U U U U U
53) TestMicroburst:
Port 1 2 3 4 5
sh diagnostic events module 8
Diagnostic events (storage for 500 events, 500 events recorded)
Number of events matching above criteria = 145
Event Type (ET): I - Info, W - Warning, E - Error
Time Stamp ET [Card] Event Message
06/16 12:19:06.759 E [8] TestNonDisruptiveLoopback Failed
06/16 12:19:19.539 E [8] TestNonDisruptiveLoopback Failed
06/16 12:19:45.120 E [8] TestNonDisruptiveLoopback Failed
06/16 12:19:57.796 E [8] TestNonDisruptiveLoopback Failed
06/16 12:20:10.568 E [8] TestNonDisruptiveLoopback Failed
06/16 12:20:10.580 I [8] TestPortTxMonitoring Skipped
06/16 12:20:23.736 E [8] TestNonDisruptiveLoopback Failed
06/16 12:20:36.512 E [8] TestNonDisruptiveLoopback Failed
06/16 12:20:49.360 E [8] TestNonDisruptiveLoopback Failed
06/16 12:21:02.193 E [8] TestNonDisruptiveLoopback Failed
06/16 12:21:15.021 E [8] TestNonDisruptiveLoopback Failed
06/16 12:21:27.685 E [8] TestNonDisruptiveLoopback Failed
06/16 12:21:27.697 I [8] TestPortTxMonitoring Skipped
06/16 12:21:39.069 E [8] diag_hit_sys_limit[8/4]: DIAG_SYS_LIMIT HIT
SP[13
%], Tx_rate[805613], Rx_rate[409032],
sp_netint_t
hr[0], flow_control[0]
06/16 12:21:51.973 E [8] DIAG_SYS_LIMIT (sp_last_busy_percent[11%],
Tx_rat
e[637546], Rx_rate[379912], sp_netint_thr[0],
flo
w_control[0]) NOT HIT
06/16 12:21:53.593 E [8] TestNonDisruptiveLoopback Failed
06/16 12:22:06.337 E [8] TestNonDisruptiveLoopback Failed
06/16 12:22:19.169 E [8] TestNonDisruptiveLoopback Failed
06/16 12:22:31.938 E [8] TestNonDisruptiveLoopback Failed
06/16 12:22:44.690 E [8] TestNonDisruptiveLoopback Failed
06/16 12:22:44.718 I [8] TestPortTxMonitoring Skipped
06/16 12:22:57.362 E [8] TestNonDisruptiveLoopback Failed
06/16 12:23:10.110 E [8] TestNonDisruptiveLoopback Failed
06/16 12:23:23.170 E [8] TestNonDisruptiveLoopback Failed
06/16 12:23:34.562 E [8] diag_hit_sys_limit[8/4]: DIAG_SYS_LIMIT HIT
SP[8%
], Tx_rate[909709], Rx_rate[436418],
sp_netint_th
06/16 12:23:47.318 E [8] DIAG_SYS_LIMIT (sp_last_busy_percent[10%],
Tx_rat
e[633368], Rx_rate[367000], sp_netint_thr[0],
flo
06/16 12:23:48.650 E [8] TestNonDisruptiveLoopback Failed
06/16 12:24:01.439 E [8] TestNonDisruptiveLoopback Failed
06/16 12:24:01.451 I [8] TestPortTxMonitoring Skipped
06/16 12:24:14.131 E [8] TestNonDisruptiveLoopback Failed
06/16 12:24:26.955 E [8] TestNonDisruptiveLoopback Failed
06/16 12:24:39.727 E [8] TestNonDisruptiveLoopback Failed
06/16 12:24:52.819 E [8] TestNonDisruptiveLoopback Failed
06/16 12:25:05.483 E [8] diag_hit_sys_limit[8/5]: DIAG_SYS_LIMIT HIT
SP[12
%], Tx_rate[906744], Rx_rate[482738],
sp_netint_t
06/16 12:25:16.936 E [8] DIAG_SYS_LIMIT (sp_last_busy_percent[9%],
Tx_rate
[552000], Rx_rate[371394], sp_netint_thr[0],
flow
06/16 12:25:18.232 E [8] TestNonDisruptiveLoopback Failed
06/16 12:25:18.244 I [8] TestPortTxMonitoring Skipped
06/16 12:25:31.872 E [8] TestNonDisruptiveLoopback Failed
06/16 12:25:44.608 E [8] TestNonDisruptiveLoopback Failed
06/16 12:25:57.324 E [8] TestNonDisruptiveLoopback Failed
06/16 12:26:10.024 E [8] TestNonDisruptiveLoopback Failed
06/16 12:26:23.064 E [8] TestNonDisruptiveLoopback Failed
06/16 12:26:35.840 E [8] TestNonDisruptiveLoopback Failed
06/16 12:26:35.852 I [8] TestPortTxMonitoring Skipped
06/16 12:26:48.581 E [8] TestNonDisruptiveLoopback Failed
06/16 12:27:01.589 E [8] TestNonDisruptiveLoopback Failed
06/16 12:27:14.505 E [8] TestNonDisruptiveLoopback Failed
06/16 12:27:14.509 E [8] hm_ndl_analyze_result mod[8]: port(fail count)
5(10)
06/16 12:27:27.253 E [8] TestNonDisruptiveLoopback Failed
06/16 12:27:39.917 E [8] TestNonDisruptiveLoopback Failed
06/16 12:27:53.001 E [8] TestNonDisruptiveLoopback Failed
06/16 12:27:53.029 I [8] TestPortTxMonitoring Skipped
06/16 12:28:05.709 E [8] TestNonDisruptiveLoopback Failed
06/16 12:28:18.442 E [8] TestNonDisruptiveLoopback Failed
06/16 12:28:31.254 E [8] TestNonDisruptiveLoopback Failed
06/16 12:28:44.110 E [8] TestNonDisruptiveLoopback Failed
06/16 12:28:57.034 E [8] TestNonDisruptiveLoopback Failed
06/16 12:29:09.874 E [8] TestNonDisruptiveLoopback Failed
06/16 12:29:09.886 I [8] TestPortTxMonitoring Skipped
06/16 12:29:22.834 E [8] TestNonDisruptiveLoopback Failed
06/16 12:29:35.574 E [8] TestNonDisruptiveLoopback Failed
06/16 12:29:48.535 E [8] TestNonDisruptiveLoopback Failed
06/16 12:30:01.715 E [8] TestNonDisruptiveLoopback Failed
06/16 12:30:14.499 E [8] TestNonDisruptiveLoopback Failed
06/16 12:30:27.263 E [8] TestNonDisruptiveLoopback Failed
06/16 12:30:27.275 I [8] TestPortTxMonitoring Skipped
06/16 12:30:40.039 E [8] TestNonDisruptiveLoopback Failed
06/16 12:30:53.019 E [8] TestNonDisruptiveLoopback Failed
06/16 12:31:05.788 E [8] TestNonDisruptiveLoopback Failed
06/16 12:31:18.456 E [8] TestNonDisruptiveLoopback Failed
06/16 12:31:31.236 E [8] TestNonDisruptiveLoopback Failed
06/16 12:31:44.060 E [8] TestNonDisruptiveLoopback Failed
06/16 12:31:44.072 I [8] TestPortTxMonitoring Skipped
06-17-2013 03:10 AM
Mr Cristian,
Diagnostic tests usually meant for checking the hardware .
Have you reseated the line card after it shown up minor error?
Before reseating the line card, set the diagnostic level to complete.
conf t
diagnostic bootup level complete
exit
If you still see the minor error in show module output, then it is an indication of hardware failure.
Inayath
*Plz rate usefull posts.
06-17-2013 07:05 AM
Hi Inauath
Thx
slot 8 is the Sup.. anyway i will do that and see if the problem reapears
