ā10-19-2010 06:18 AM - edited ā03-06-2019 01:36 PM
I've just added 6708 card into 7600 chassis (slot 7) and trying to move some highload interfaces from the same card (slot 4) to it without success.
Interface with exact l2 configuration on module 4 is forwarding traffic, but on module 7 don't.
Need your help.
Thanks.
ā10-19-2010 08:01 AM
Can you post output of "sh module"
What ports are you using on the module in slot 4 and what ports are you trying to move to on the module in slot 7 ?
Jon
ā10-20-2010 01:00 AM
Card have been moved to slot 8, with the same issue.
#sh module
Mod Ports Card Type Model Serial No.
1 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1108HT6V
2 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL1137061N
3 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAD110502N6
4 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL1252EBMY
5 2 Route Switch Processor 720 (Active) RSP720-3CXL-GE JAE1113ATQR
8 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL1252EBMW
Mod MAC addresses Hw Fw Sw Status
1 001a.a10e.a9d0 to 001a.a10e.a9ff 2.5 12.2(14r)S5 12.2(33)SRE1 Ok
2 001d.4553.06a4 to 001d.4553.06bb 2.6 12.2(14r)S5 12.2(33)SRE1 Ok
3 0019.e78f.ad0c to 0019.e78f.ad13 1.3 12.2(18r)S1 12.2(33)SRE1 Ok
4 0023.0455.da98 to 0023.0455.da9f 1.6 12.2(18r)S1 12.2(33)SRE1 Ok
5 0019.5679.9188 to 0019.5679.918b 5.2 12.2(33r)SRB 12.2(33)SRE1 Ok
8 0023.0455.db98 to 0023.0455.db9f 1.6 12.2(18r)S1 12.2(33)SRE1 Ok
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC SAL1101CZA3 2.1 Ok
2 Centralized Forwarding Card WS-F6700-CFC SAL11380T9W 4.0 Ok
3 Distributed Forwarding Card WS-F6700-DFC3CXL SAD1108079W 1.0 Ok
4 Distributed Forwarding Card WS-F6700-DFC3CXL SAL1253ESFD 1.2 Ok
5 Policy Feature Card 3 7600-PFC3CXL JAE1114B8V4 1.0 Ok
5 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE1114B72W 1.0 Ok
8 Distributed Forwarding Card WS-F6700-DFC3CXL SAL1251DNLG 1.2 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
4 Pass
5 Pass
8 Pass
interface TenGigabitEthernet4/3
switchport
switchport trunk native vlan 1001
switchport trunk allowed vlan 108,901-920
switchport mode trunk
load-interval 60
mls qos vlan-based
no cdp enable
spanning-tree vlan 89,184,378,900-949 cost 16
interface TenGigabitEthernet8/3
switchport
load-interval 60
mls qos vlan-based
no cdp enable
#sh int te4/3 | i rate
Queueing strategy: fifo
1 minute input rate 4648757000 bits/sec, 778522 packets/sec
1 minute output rate 6501773000 bits/sec, 932056 packets/sec
When I moved transceiver from 4/3 to 8/3 I haven't seen any packet or bit on interface counters:
#sh int te8/3 | i rate
1 minute input rate 0 bits/sec, 0 packets/sec
1 minute output rate 0 bits/sec, 0 packets/sec
ā10-20-2010 08:50 AM
Volia,
I hope both interfaces are in up/up status. If so, is this just a counter issue or traffic getting dropped ?
Also, I would like to check "sh int Tenx/y trunk" from both interfaces and compare.
I hope you checked the ingress/egress traffic rate at remote-end device (at other end of Ten8/3).
- Yogesh
ā10-21-2010 03:00 AM
Of course interfaces are UP.
For testing pruposes I've tried to move another interfaces (channel gorup members) module4 -> module8.
#sh ethercha 1 port-cha
Port-channels in the group:
Port-channel: Po1
Age of the Port-channel = 105d:06h:09m:16s
Logical slot/port = 14/1 Number of ports = 4
GC = 0x00010001 HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = PAgP
Fast-switchover = disabled
Direct Load Swap = disabled
Ports in the Port-channel:
Index Load Port EC state No of bits
0 11 Te3/7 Desirable-Sl 2
1 22 Te3/8 Desirable-Sl 2
2 44 Te8/7 Desirable-Sl 2
3 88 Te8/8 Desirable-Sl 2
Time since last port bundled: 0d:00h:06m:33s Te8/7
Time since last port Un-bundled: 0d:00h:06m:57s Te4/7
Last applied Hash Distribution Algorithm: Fixed
Channel-group Iedge Counts:
Access ref count : 0
Iedge session count : 0
#sh int status | i Te8/(7|8)
Te8/7 router-1 po1-4 connected trunk full 10G 10Gbase-LR
Te8/8 router-1 po1-2 connected trunk full 10G 10Gbase-LR
#sh int te8/7 trun | b not_pruned
Port Vlans in spanning tree forwarding state and not pruned
Te8/7 1,3,6-12,14-39,65,89,100-117,122-126,150,184,252-259,300,361-362,371-372,378,400-401,403-407,450-451,849,854,901-918,950,952-956,959-966,970,973
#sh int te8/8 trun | b not_pruned
Te8/8 1,3,6-12,14-39,65,89,100-117,122-126,150,184,252-259,300,361-362,371-372,378,400-401,403-407,450-451,849,854,901-918,950,952-956,959-966,970,973
And counters:
#sh int te8/7 | i rate
#sh int te8/8 | i rate
on remote end:
#sh int te4/7 | i rate
1 minute input rate 2928488000 bits/sec, 384769 packets/sec
1 minute output rate 3349734000 bits/sec, 416090 packets/sec
#sh int te4/8 | i rate
1 minute input rate 2922607000 bits/sec, 389096 packets/sec
1 minute output rate 3324800000 bits/sec, 413804 packets/sec
I'm totaly discouraged.
ā10-21-2010 04:07 AM
Okay, please don't be discouraged but please do answer the questions being asked ie.
is this is a cosmetic issue with the counters or is traffic actually not being forwarded on these links ie. have you lost network connectivity ?
Jon
ā10-21-2010 04:27 AM
Need some time for investifation.
ā10-21-2010 05:34 AM
Thanks for providing all the details.
From looking at the counters captured at the remote end, I see the input rate non-zero. I believe it is just a counter issue.
Please do "sh counters int Ten8/x" and see if the counters incrementing.
- Yogesh
ā10-25-2010 05:55 AM
Thanks to all.
Interface counters issue in action.
