6807 cisco switch
unajibi2002
How to change rstp to pvstp in 6807 cisco switch
Duplicate post with this
Kind Regards
Paul
johnd2310
Level 8
Level 8
 By pvstp do you mean per vlan spanning tree and rapid spanning tree for rstp? You can no run rstp on the switch. The rstp equivalent on the 6807 is  rapid-pvst or rapid per vlan spanning tree.
I think on the 6807 you can only run rapid-pvst and mst. You cannot run pvst(old)
John
**Please rate posts you find helpful**
Kind Regards
Paul
