08-10-2018 02:37 AM
i received form our customer a cisco 7200 broken, i found this situation below:
System Bootstrap, Version 12.3(4r)T1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2003 by cisco Systems, Inc.
C7200 platform with 1048576 Kbytes of main memory
Readonly ROMMON initialized
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
loadprog: error - on file open
boot: cannot load "cisco2-C7200"
string is disk2:c7200-adventerprisek9-mz.124-24.T.bin
loadprog: bad file magic number: 0x0
boot: cannot load "disk2:"
rommon 13 > dev
Devices in device table:
id name
bootflash: boot flash
slot0: PCMCIA slot 0
slot1: PCMCIA slot 1
disk0: PCMCIA slot 0
disk1: PCMCIA slot 1
slot2: PCMCIA compact flash
disk2: PCMCIA compact flash
eprom: eprom
rommon 19 > dir bootflash:
File size Checksum File name
rommon 20 > dir slot0:
rommon 21 > dir slot1:
rommon 22 > dir disk0:
rommon 23 > dir disk1:
rommon 24 > dir slot2:
Directory of slot2:
13136 1068 -rw- c7200-adventerprisek9-mz.124-24.T.bin
rommon 25 > dir disk2:
Directory of disk2:
rommon 26 > dir eprom:
8936 bytes (0x22e8) 0x847c uncompress
55505 bytes (0xd8d1) 0x294e c7200-fslib-m
65937 bytes (0x10191) 0x2d4a c7200-atafslib-m
Can you help me to start up this 7200??
Thanks in advance
RGD
Solved! Go to Solution.
08-10-2018 07:39 AM
Hello Loe,
thanks for your time dedicate to me .
I fixed the issue , I used a CF usb reader and I uploaded new image file .
Thanks again
08-10-2018 02:51 AM
08-10-2018 02:54 AM
Hello Leo,
thanks for your reply here the result:
rommon 4 > boot slot2:c7200-adventerprisek9-mz.124-24.T.bin
boot: cannot load "disk2:c7200-adventerprisek9-mz.124-24.T.bin"
Thanks for your attention
RGD
08-10-2018 03:46 AM
08-10-2018 03:50 AM
OK but How I can download it again?
Seems on rommon i cannot use xmodem and also tftpdnld see below:
rommon 4 > xmodem
monitor: command "xmodem" not found
rommon 5 >
rommon 5 > tffpdnld
monitor: command "tffpdnld" not found
rommon 6 >
rommon 6 >
rommon 6 > help
alias set and display aliases command
boot boot up an external process
break set/show/clear the breakpoint
confreg configuration register utility
cont continue executing a downloaded image
context display the context of a loaded image
cpu_card_type display CPU card type
dev list the device table
dir list files in file system
dis disassemble instruction stream
frame print out a selected stack frame
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
rommon-pref Select ROMMON
set show all monitor variables
showmon display currently selected ROM monitor
show_spd show all SPD data
stack produce a stack trace
sync write monitor environment to NVRAM
sysret print out info from last system return
unalias unset an alias
unset unset a monitor variable
rommon 7 >
Thanks for your help
08-10-2018 04:05 AM
08-10-2018 05:03 AM
08-10-2018 07:39 AM
Hello Loe,
Thanks again
08-10-2018 05:25 AM
Did you ever used this router ?
My guess is that it is configured to get only rommon mode.
So you might try to modify confregister as follow then reload :
confreg 0x2102
reset
Jérôme
08-10-2018 07:38 AM
HelloJjerome,
thanks for your reply, I fixed the issue , I used a CF usb reader and I uploaded new image file .
