135
Highlighted
Beginner
7841 Phone not recognizing Voice VLAN
I am running into an issue with getting NEW Cisco 7841 phones to register with Call Manager. Investigation shows the phones are not recognizing the voice VLAN.
Here is a config snippet that has worked with 250 7900 series phones for 8 years:
interface GigabitEthernet1/0/16
description PHONE-PC PORT
switchport access vlan 109
switchport trunk native vlan 109
switchport mode trunk
switchport voice vlan 209
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
What I have found is that if I remove the line "switchport trunk native vlan 109" the phone registers with the voice VLAN and everything seems to work properly.
Here are my questions:
1/ What has changed between the old 7900 series phones and the NEW 7800 series
2/ What is the proper way to correct this?
3/ By removing the "Native VLAN" from the switchport, does that mean the PC will now be forced into VLAN 1?
Brian
1 REPLY 1
Highlighted
Hall of Fame Expert
You don't need a trunk port. So, just need a voice vlan and a data vlan, which you already have defined. So, you can just delete these 3 command and it should work fine.
Content for Community-Ad
